20 Most Recent Maytag MBL2258XES 21.9 cu. ft. Bottom-Freezer Refrigerator 5 Questions & Answers
0answers
Where is the defrost timer located on a Maytag upright freezer model RFU200FAAW?
Most parts are obsolete, and the timer is expensive! https://www.repairclinic.com/ProductDetail/96494?page=3 Timer-Def Part Number:WP3-81329 In Stock, 1 available Note: (Series: B2) $82.10 Add to Cart 16 Defrost Heater Part Number:W11175809 In Stock Note: (Series: B2) The defrost heater keeps the cooling coils from frosting over. $71.30
10/2/2021 9:10:41 PM • Maytag Freezers • Answered on Oct 02, 2021
2answers
My maytag frezzer icebox is groaning
its the fan
1/15/2019 12:17:44 AM • Maytag Freezers • Answered on Jan 15, 2019
Refridgarator is not cooling
thermostats are usually a "on/off" switch just as a simple light switch. Ohms on a defrost timer is not very specific. It is basically a switch that turns heaters on and off while keeping the compressor off during the defrost cycle. Your thermostat may be sticking/hanging up.
8/11/2017 2:10:41 AM • Maytag Freezers • Answered on Aug 11, 2017
ICE BUILD UP IN A MAYTAG MODEL MZF34X16DW UPRIGHT FREEZER
I have had a few of these, and others of the same ilk. Your problem should be air leakage into the machine. Take a thicker piece of paper, not cardboard, and try to slide it around the gasket where the door gasket contacts the front of the freezer. The gasket should be firm enough to prevent the paper from sliding. Wherever you can move the paper, you could have a air leak. Most of these have no adjustment in the latch to tighten the door. Sometimes a new gasket will solve the problem, sometime a new door will. P.S. Twice I have tied a new freezer to a refrigerator dolly to move it and have accidentally warped the door, and they cannot be straightened. :-( God bless your efforts.
7/7/2017 6:22:49 PM • Maytag Freezers • Answered on Jul 07, 2017
Refrigerator not dispensing water or ice
repairs should be performed by a qualified technician. if there isn't ice in the ice bucket located in the freezer you have a water flow problem. if there is water going to the filter and nothing out of the freezer then you have a clogged freezer replace it. if these things are ok then yes it could be the electronic control. filter failure is a common problem.
5/2/2017 7:04:48 PM • Maytag Freezers • Answered on May 02, 2017
Fridge keeps running non-stop
thermostat
3/10/2014 6:30:32 PM • Maytag Freezers • Answered on Mar 10, 2014
Maytag MBL2258XES 21.9 cu. ft. Bottom-Freezer Refrigerator 5 Logo
6 questions posted
Top Maytag Freezers Experts
john h
ADMIN Andrew
ADMIN Andrew
vince
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
View Most Popular
Maytag Freezers
  • Maytag Freezers
Most Popular Question
maytag upright freezer mqu1556aew l1 top
  • Freezers
