20 Most Recent
Samsung RF266AEBP Questions & Answers
Freezer and fridge not working and starting to
it may be froze up, and require a defrosting. use a portable fan to
speed up this process , also make sure the fan in the freezer
compartment is working, with a little work and a zoom spout oiler, or
some light motor oil, the motor can be sparked back to life.. freeze ups
are common with the high humidity we are having these days.. jay the
pool pump motor repair guy longwood Florida
Good day. My Samsung fridge/freezer SR-S22FTFB runs normal for the first few hours when been switched on, both fridge and freezer temperatures were set for (- 18 and 2), both fans are running and when
Hello Danie;
My name is Peter. I am a retired field service refrigeration technician.
The normal setting for a freezer is -2 to +2 degrees F., and the normal setting for the fresh food section is +35 to +40 degrees F.
You only have one source of cooling and that is your freezer. With the settings that you have, you are asking your unit to do what it is not designed to do.
The ice maker is struggling because if it is a cast steel ice cube mold, the heater beneath it is not designed for the current to break the ice cubes free @ -18 degrees F., or if you have a plastic flex ice cube mold it is too ridged to flex enough to break the ice cubes free. Normally your ice maker should dump 8-10 times in a 24 hour period.
A note on food storage. Make sure you do not overload your freezer of fresh food section to the point where food product extends beyond the edge of the shelves.
I changed clicks and relays but wires at the compressor burned,only fan runs but compressor still cant start,whats wrong and where is the thermostat?
Hello;
Your problem is not your thermostat. In some models the compressor knocks out the overload relay. They relay could last a few seconds or a few weeks before the compressor knocks it out again. This is especially turn with the LG units.
You will need a multi-meter to check your compressor.
1.) Unplug your unit. Remove the bottom back cover.
2.) Remove the overload components to expose the 3 pins on the compressor.
3.) Inspect the pins on the compressor. Are they clean or are they damaged from heat (Steel melting).
4.) With your multi-meter, set the meter on the lowest Ohms. Read the Ohms between each of the pins. You will have 3 readings. One reading will be high and the other 2 readings will be lower. Add the 2 lower readings together. This value must equal the high reading within a few tenths.
I hope I am wrong. A new compressor depending on the model is $275-$450.00. Include a system filter for $40.00, plus new refrigerant $45.00 and the cost od an experienced technician $300.00.
