20 Most Recent Kenwood Ax950 Attachment For Kmix Stand Mixer Meat Grinder Questions & Answers
2answers
Kmix mincer not rotating
Hi, it sounds like a broken gear. Send me your email
12/4/2013 6:22:49 AM • Kenwood Ax950... • Answered on Dec 04, 2013
Where can I get a replacement parts for kenwood km632?
If in the UK try espares; https://www.espares.co.uk/search/mo2748942/kenwood/blenders---mixers---juicers/km631-major-silver-+-at337 They may ship abroad ... I don't know, I am UK based.
12/19/2023 7:50:24 AM • Kenwood Food... • Answered on Dec 19, 2023
My kenwood multipro 910 food processor not working
Check the power supply: Ensure that the food processor is properly plugged into a functioning power outlet. Sometimes, a loose connection or a tripped circuit breaker can cause power issues.
Safety interlock system: The Kenwood Multipro 910 food processor usually has a safety interlock system that ensures all parts are properly assembled before it can start. Check if all the components, such as the bowl, lid, and blade, are correctly locked into place. If any of the parts are not properly assembled, the food processor may not work.
Motor overload protection: If you have been using the food processor for an extended period or with heavy ingredients, the motor may have overheated and triggered the overload protection mechanism. In this case, you will need to allow the motor to cool down for some time before it can restart.
Fuse or circuit breaker: Some food processors have a built-in fuse or circuit breaker that protects the motor from electrical surges. Check if your food processor has a fuse and ensure that it is intact. If it has a circuit breaker, reset it if necessary.
Mechanical issues: If none of the above steps resolve the problem, there might be a mechanical issue with the food processor. It could be a faulty motor, broken wiring, or a malfunctioning switch. In such cases, it is advisable to contact the Kenwood customer support or take the appliance to an authorized service center for repair.
7/16/2023 12:10:20 PM • Kenwood Food... • Answered on Jul 16, 2023
Hi, I have an old kenwood chef a701a with 2 tube like capacitors. Do you know what I can replace them with and if I need 2 capacitors.I know one is 0.1 mf and the other is 0.01mf.Thanks
You need to contact an electronic component supplier, there are many on line, they can answer that question for you.
6/24/2023 9:07:24 AM • Kenwood Food... • Answered on Jun 24, 2023
2answers
Kenwood Chef Premier can run at all speeds for the first few seconds. Then it runs slower and you can tell by the sound.
It sounds like there may be an issue with the motor in your Kenwood Chef Premier mixer. This could be caused by a variety of factors, such as a malfunctioning motor, a problem with the drive belt or gears, or an issue with the electrical components of the mixer. To troubleshoot the problem, you may want to try cleaning and lubricating the drive belt and gears, as well as checking the electrical connections and fuses.
1/8/2023 6:02:28 AM • Kenwood Food... • Answered on Jan 08, 2023
2answers
Kenwood kmix doesn't start
Help in the link including from Kenwood themselves. It is likely to be the selector, the control board or the motor. Take it in for Dealer Service. https://www.google.com/search?q=Kenwood+kmix+doesn%27t+start ..
12/8/2022 4:10:34 AM • Kenwood Food... • Answered on Dec 08, 2022
3answers
Circuit/wiring diagram for KENWOOD CHEF - Model A701A
BRG1 Please can you also email this to me
mal at speciss.co.zw
5/29/2022 4:38:44 AM • Kenwood Food... • Answered on May 29, 2022
Is is worth repairing a Kenwood Prospero stand mixer km24?
If you have a multi meter check the box caps and resistors for KM 2XX series then replace it whenever required. Some may differ in values like 0.15uF 275x2, 0.33uF 275X2 or 0.47uF 275X2 then resistors may also differ with different models but common to have 1.1k ohms 2watts. Also if caps are open it is good to check the 600V triac and replace it when giving out lower output. I also advise to clean the commutator esp when is is sparking a lot, you may use light sanding and clean it after. Check also if the tachometer is good, there is a resistor-like-coil hidden under a plastic tab with 2 wires. This gives feedback and via a magnet attached to the shaft. Check the motor brush if it is good or worn out. Lastly check all the switches because if one of them is not working properly you wont be able to let the motor run.
3/15/2022 9:48:12 AM • Kenwood Food... • Answered on Mar 15, 2022
Model A701. What type of grease/oil is used in the gearbox and how much?
A white or clear lithium grease. Do not cake it on but enough to get into all of the cogs/worm gears.
1/12/2022 2:35:19 AM • Kenwood Food... • Answered on Jan 12, 2022
Kenwood Major A717 Grease?
I use white food safe grease. Here is an example; https://www.ebay.co.uk/itm/391996333570?epid=25018211366&hash=item5b44cd5e02:g:NlUAAOSwoeVdxAPv
12/6/2021 9:59:23 PM • Kenwood Food... • Answered on Dec 06, 2021
2answers
Kenwood chef repairs team my mixer motor works but beaters won't rotate
We are FIXYA dot com, we aren't Kenwood Chef, we aren't who you think we are. There can be two reasons for a Kenwood Chef to run but not turn the beaters. The most likely one is that the Drive belt has broken. Or You have strained the beaters and you have sheared the shear pin in the drive shaft. It is there to save you damaging the motor and gearbox. Take the top cover off https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk00zPgmBhh6OuyNypTqtItnqQKaGMw%3A1615571990471&ei=FqxLYIuQHJDQsAW1nJyICw&q=Kenwood+chef+beaters+not+turning ..
3/12/2021 6:02:59 PM • Kenwood Food... • Answered on Mar 12, 2021
3answers
How to reassemble Kenwood A700D
Hi, I can help you also and send you a complete pdf file of the original service manual. Please send me your email.
1/13/2021 7:26:42 PM • Kenwood Food... • Answered on Jan 13, 2021
I have a Kenwood KA 893. I have no control over the volume. The dial is spotty. Sometimes I can turn the volume up but it usually does what it wants. I do not have the remote.
Sounds to be dirty. There is a thing called tuner cleaner you can use to clean it. You will need to remove the control knob and try spraying into the control,but you may have to get inside to clean it up good by breaking down the unit.
11/23/2020 12:24:38 AM • Kenwood Food... • Answered on Nov 23, 2020
Kenwood Ax950 Attachment For Kmix Stand Mixer Meat Grinder Logo
1 questions posted
Top Kenwood Food Mixers Experts
vince
Ngoro
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
Kenwood Food Mixers
  • Kenwood Food Mixers
Most Popular Question
kmix mincer not rotating
  • Food Mixers
