20 Most Recent Franke Evolution One Step Espresso Machine Questions & Answers
Franke Little Butler FH-160. My instant hot water heating tank leaks when in use.
Check other parts suppliers. It can only be an O-Ring or a compression fitting. https://www.google.com/search?q=frankie+little+butler+fh-160+parts+diagram ..
12/13/2023 7:47:37 PM • Franke Coffee... • Answered on Dec 13, 2023
Hi, we have a Franke Evolution 1. Working without problems except the espresso is coming out too cold. Any ideas?
Question edited for clarity 'to colt' to 'too cold'. Some people like the cold brew stuff. :>D
5/31/2023 6:22:08 PM • Franke Coffee... • Answered on May 31, 2023
2answers
Anything with milk won't be hot just warm?
Hi, if you're adding in the milk prior to the cofee being made, then please add it towards the end. If adding and the beginning, then vice versa. It sounds like the milk is exceedingly colder than any water that you're loading into the machine. You might try using powdered milk so that the milk that you use will be at room temperature. Thank you.
11/9/2022 5:50:00 PM • Franke Coffee... • Answered on Nov 09, 2022
2answers
Error 036 Fill Boiler 1 - Franke Spectra
Hi, Please restart your machine. Check pump pressure, boiler valve and the water supply. You can check the manual for more details. I believe it should be on page 9 and/or the table of errors. Thank you.
11/2/2022 5:41:39 AM • Franke Coffee... • Answered on Nov 02, 2022
Where i can find spare parts catalog for franke a600 I need spare parts for franke a600 brewing unit. where i can find spare part namber?
We got our parts from Franke top engineers at www.coffeeoffice.ie Competitive prices and very friendly service.
9/2/2022 8:18:37 PM • Franke Coffee... • Answered on Sep 02, 2022
3answers
Franke A200 Coffee Machine not turning on.
Question moved from Washing Machine category. Test the switch with a multimeter for power both sides. If the switch is working, you have done everything that a consumer can do. You will have to take it in for service. It may need a new control board.
9/1/2022 11:27:42 AM • Franke Coffee... • Answered on Sep 01, 2022
How do I unblock the steam wand on my franke flair coffee machine.
I had a Franke Flair machine in an airport business class lounge. We had a steam wand blocked for safety reasons. Check out the video in the link. https://www.google.com/search?q=Franke+flair+unblock ..
5/15/2022 7:42:26 PM • Franke Coffee... • Answered on May 15, 2022
Franke Flair coffee machine getting blocked message on screen I rang the seller and he says it's blocked for public safety? How do I unblock this as he says he does not know?
I had a Franke Flair machine in an airport business class lounge. We had a steam wand blocked for safety reasons. Check out the video. https://www.google.com/search?q=Franke+flair+unblock ..
5/15/2022 7:41:58 PM • Franke Coffee... • Answered on May 15, 2022
No milk and steam dispensing from Franke Flair coffee machine
I am a Franke technician. After and possibly during the descale, because probably you haven'nt done it in a long time, steam was able to escape through the fittings as the limescale damaged the silicone rings beforehand. The steam damaged the klixxons or the thermoblock itself. You will need one of us unfortunately....
3/16/2022 5:58:46 PM • Franke Coffee... • Answered on Mar 16, 2022
2answers
Is ther a franke engineer in the limerick area to fix a malfunction 4 ona flair 654 coffee maker
I would contact your supplier or the manufacturer for advice. You don't want someone who is not an authorised repair agent because they may not be able to get specific spare parts.
12/20/2021 12:42:46 PM • Franke Coffee... • Answered on Dec 20, 2021
Franke coffee machine type 790 water is leaking near power cord
best bin it before it electrocutes someone
4/24/2021 11:40:14 PM • Franke Coffee... • Answered on Apr 24, 2021
My franke flair coffee machine is telling me to fill bean hopper but it’s already full. Can you help?
https://www.youtube.com/watch?v=RcsT1SdxbdE
4/15/2020 3:10:17 PM • Franke Coffee... • Answered on Apr 15, 2020
Franke Flair Typ 654 safety cutoff behind the flaps keeps shutting the machine off why
Have you descaled the coffee maker? A water path clogged with calcium buildup will not allow the water to pass through quickly enough and cause s starvation flow.
4/6/2020 10:40:24 PM • Franke Coffee... • Answered on Apr 06, 2020
Where are the breakers on a franke flair bean to cup machines
https://www.youtube.com/watch?v=4z4tZ4PEKOE
3/30/2020 2:54:21 PM • Franke Coffee... • Answered on Mar 30, 2020
My Franke coffee machine keeps saying to fill water tank but it is full and I can’t use it. Any ideas please?
Check the water level sensor on tank,often gets a bit of lime scale on it.Remove it give it a clean and replace and check
6/30/2019 12:21:28 PM • Franke Coffee... • Answered on Jun 30, 2019
Hi, my Franke Flair does not respond when I push any of the buttons to make coffee, water, milk etc. it just displays the 'SELECT PRODUCT' message. The rinse, clean and descale buttons all work.
Unplug unit to reset the settings completely...If you have the same problem call manufacturer to save time...
1/30/2019 9:47:16 AM • Franke Coffee... • Answered on Jan 30, 2019
Franke Evolution One Step Espresso Machine Logo
1 questions posted
Top Franke Coffee Makers & Espresso Machines Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
john h
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Franke Coffee Makers & Espresso...
  • Franke Coffee Makers & Espresso...
Most Popular Question
franke evolution 1 working without
  • Coffee Makers & Espresso Machines
