20 Most Recent
Levelone CP TECHNOLOGIES LEVELONE CABLE/DSL ROUTER W/4-PORT SWITCH (Retail) (FBR1418TX) Questions & Answers
D-link dir 412 n150.default password
Connect a LAN cable from the D-Link to your laptop/computer's
LAN port, open the browser on your laptop/computer and enter the D-Link's
configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)
You can now change the default admin password.
You can now configure the wireless settings.
(SSID, WPA or WPA2 encryption to protect your wireless network and
Internet from unauthorized access).
Now configure the wireless card in your computer/laptop with
the router's wireless settings.
To secure your wireless network from unauthorized access,
please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
D-LINK DIR 412 N150 USERNAME 'PASSWORD
If the default password on the D-Link has been changed then -
To reset the D-Link back to the default settings - Press and hold the RESET button at the back of the router with the power ON
until the LEDs flash at the time the release the RESET button.
configuration URL..
http://192.168.0.1
No connection after lightning and thunder
There's ALWAYS the chance of damage.
If you have reset both the router and the cable modem and it still doesn't work, bypass the router and try connecting the system directly to the Cable/DSL modem. If your computer works in that situation the router has been affected, double check your connections between modem & router AND between router and computer.
If you still cannot connect, call your internet provider and inquire re: system status in your area. If all is good ask them if they can 'see' your modem. They will check their equipment to see if your modem is connected and communicating with their system. If they don't find it the modem is suspect.
If they can see the modem but you are still unable to connect to the internet via the router/switch, then the router/switch is the culprit.
Of course this all assumes everthing is OK with your computer. Otherwise this becomes a much larger troubleshooting issue. But let's not go there yet.
BIG TIP: Invest in a lightweight UPS or a line conditioner, particularly one that will protect your inbound Internet connection (coax or phone line) as well as the Ethernet port protection you need. In the end it's a LOT cheaper than replacing lightning damaged hardware.
Surge Protectors are of limited value because a majority (80% or more) of all power related electronic issues, especially regarding solid state circuitry, is due to BROWNOUTS, not surges. Something the manufacturers of surge suppression strips & related hardware are reluctant to admit, but that's why they can reliably afford to insure their surge protectors for ridiculous sums.
Apply this same principle to home entertainment systems, tv's (especially LCD & Plasma), game consoles, and any other valuable home electronics.
LevelOne WBR-6005 Router WIFI Problem
Try a different wireless device, e.g., iPod Touch, or iPhone, or Android mobile-phone, to see if any of them can connect to your wireless network.
5/29/2017 12:36:06 PM •
Levelone...
Answered
on May 29, 2017
LevelOne WBR-6005 Router WIFI Problems
Open "Network Connections" on your wireless laptop, and check that the wireless adapter is "enabled". Look for a slider-switch on your computer that may "enable/disable" your wireless adapter.
2/5/2015 8:06:36 AM •
Levelone...
Answered
on Feb 05, 2015
Webcam driver for xp
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7
http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here
rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your
Java, Flash and
Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP:
DirectX 9.0c - Windows Vista
: DirectX 10).
http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Hope this helps.
1/11/2013 11:22:39 PM •
Levelone...
Answered
on Jan 11, 2013
