20 Most Recent Nostalgia Electrics PIE-400 4-Pie Electric Pie Bakery Questions & Answers
You may download a copy of the manual here.
Nostalgia... | Answered on Nov 24, 2012
It Could Be a Number of Things..
It's most likely that the electrical Wire Could Have a Shortage, If it cuts off again Try gently Wiggling the Electrical Wire in a Number of Directions If it cuts on and off while your fidgeting with it, you've found your Problem! A quick fix would be to Adjust the wire In the position it would cut on the strongest, wrap the cord with Tape to Keep the wire in that Position, this will Prevent it from shorting again.
Either that or you simply put too much product in the Blender with an inadequate amount of liquid.
Blenders | Answered on Oct 06, 2019
typically, you can't repair it.
Blenders | Answered on Sep 14, 2019
that happens to the best of them. Try heat soap, vinegar, and a tight grip to get it off.
blenders are:
power cord, switch, speed control, and motor.
A disassembly and VOM meter is required to determine which part is defective.
Use https://www.google.com and the words manual and whatever manufacturer and model it is to see manuals.
Blenders | Answered on Sep 11, 2019
Fixya does not sell Intertek parts. Intertek might be a source.
Blenders | Answered on Aug 25, 2019
Is probably a binding problem with the motor shaft bearing or the circuit card is fried. If you've tried giving it a good cleaning and that didn't work it's a good bet the unit is junk. Suggest buy a new one.
Blenders | Answered on Aug 17, 2019
Go on the Logik blender website and request parts info.
Most small appliances cost more to repair than they are worth. Unless it needs a simple switch or a cord plug it's probably junk. Suggest buy a new device.
As stated earlier it could be the shaft needs lubing, remove the bottom part of the blender blade... the rubber thing that engages on the motor. I started with WD-40 and worked some lithium grease into it. Spins like new now.
Blenders | Answered on Jun 25, 2019
Nostalgia Electrics PIE-400 4-Pie Electric Pie Bakery Logo
2 questions posted
Top Nostalgia Electrics Blenders Experts
eyecam
Marvin
Marvin
Ross Keen
Are you a Nostalgia Electrics Blender Expert? Answer questions, earn points and help others
View Most Popular
  • Nostalgia Electrics Blenders
Most Popular Question
need manual
  • Blenders
