20 Most Recent
Wareforce CG Underbar Glass Washer 208/230V Questions & Answers
How to adjust water temp
Measure the temperature of the incoming water from your water source. Adjust water source temp to around 130 degrees, or what is required by data plate.
http://www.webstaurantstore.com/documents/pdf/wareforce_cg_service_manual.pdf
Hot water gets 200 degrees breaks glasses
You need to ensure the incoming water temperature matches the requirements on the data plate, normally around 130 degrees.
How to adjust hot water Gets too hot
Check you data plate. The inlet temperature must match the machine requirements, which means that your incoming water is too hot and the water heater temperature needs to be turned down. Here is a link to a installation/service manual. http://www.webstaurantstore.com/documents/pdf/wareforce_cg_service_manual.pdf
What is error code c8 mitsubish heater
The P8 fault can mean many things when it pops up on your Mitsubishi Electric wall controller. The P8 fault is activated when the indoor coil sensor does not change the temperature for a set amount of time after the compressor is (or should be) switched on.
Rival titan floor heater coils don't turn red
Beware when working with electrical equipment. It may cause electric shock.
Check the power supply wires, connections with heating coils. If they are ok then possibly heating coils require replacement.
