20 Most Recent
Jura Impressa Z7 One-Touch Automatic Coffee Center Questions & Answers
Jura z7 error message empty coffee tray when tray s not full
Yo James,
I know nothing of your unit, but I've never let that stop me before??.
Sounds like a sensor is stuck in the "tray full" position and popping an error message based upon what "it" is detecting.
OK, how does the unit know from "full tray" (what ever that means). I'm a big believer in problems being created by dirt, crud and in your case, coffee grounds. Unless the sensor (switch?) itself has failed, I'll bet there is debris fouling the system.
Find the "full tray" (what ever that means ??) sensing mechanism and clean/replace it and I'll bet you will solve the problem.
All the best.
What is error code c8 mitsubish heater
The P8 fault can mean many things when it pops up on your Mitsubishi Electric wall controller. The P8 fault is activated when the indoor coil sensor does not change the temperature for a set amount of time after the compressor is (or should be) switched on.
Rival titan floor heater coils don't turn red
Beware when working with electrical equipment. It may cause electric shock.
Check the power supply wires, connections with heating coils. If they are ok then possibly heating coils require replacement.
