20 Most Recent Microsoft Windows XP Home Edition with Service Pack 2b for PC Questions & Answers
5answers
Excel file corrupt how to recover
Better Stellar Phoenix Excel Recovery which can fix corrupt Excel (.XLS/.XLSX) files and restore everything (including charts, chartsheets, cell comments, worksheet properties etc.
5/20/2019 8:50:09 AM • Microsoft... • Answered on May 20, 2019
2answers
Al instalar el windows xp home edition me pide un
instalar
6/6/2016 6:26:24 AM • Microsoft... • Answered on Jun 06, 2016
Packard bell
Packard Bell computers are realy too old to be running xp. Consider buying a new or used PC
5/24/2014 4:23:07 AM • Microsoft... • Answered on May 24, 2014
Mixi dj is a spam, toolbar, etc...
Go to: tools>extensions>enable/disabel this ad
7/21/2013 12:51:28 AM • Microsoft... • Answered on Jul 21, 2013
C:\windows\system 32\mshtml.hlp
jst repair or reinstall your window.and your PC will work properly........
5/29/2011 6:23:18 PM • Microsoft... • Answered on May 29, 2011
Windows Xp os service pack 2 CD KEY ?
If you have lost the CD Key Call up the Microsoft call center no, you may have to produce the bill copy.
Or else from the installed system using third party utility you can find the CD-Key installed on your system.
9/11/2010 2:16:36 PM • Microsoft... • Answered on Sep 11, 2010
2answers
Is there a fairly small download file for Service pack 2 for XP
First of all perform a speed check on your internet speed. I recommend speedtest.net for that.
If your speed is less than 2mbps then the file could take a while to download.
Try clicking on the links that i will provide bellow, use them one at a time and see if the download estimation changes.
http://www.softwarepatch.com/windows/xpsp2.html
http://www.soft32.com/Download/Free/Windows_XP_Service_Pack_2/4-992-1.html
http://www.topshareware.com/Windows-XP-SP2-download-17215.htm
http://www.microsoft.com/downloads/details.aspx?FamilyId=049C9DBE-3B8E-4F30-8245-9E368D3CDB5A&displaylang=en
Good luck and regards.
2/1/2010 4:18:36 AM • Microsoft... • Answered on Feb 01, 2010
Im having trouble installing winows service pack3
no u dont have to do it.
see if ure xp is genuine that is registered and sp3 is not this problem occurs. another reason is ure installation source may be damaged. u can try either to copy the sp3 contens to ur hard drive and try instaling from there.
12/9/2009 2:57:21 AM • Microsoft... • Answered on Dec 09, 2009
Hal.dll file missing or corrupted
Follow the steps given in the link below to troubleshoot the hal.dll missing issue:
http://support.microsoft.com/kb/945380
9/3/2009 7:26:09 AM • Microsoft... • Answered on Sep 03, 2009
I want to reprogram a key on my keyboard from a
I program called Keytweak at http://webpages.charter.net/krumsick/ can be used to remap any key to any other. But I'm not sure if you can remap the "printer" key since that is non standard. The best idea is to try it, it is free.
8/28/2009 7:48:53 PM • Microsoft... • Answered on Aug 28, 2009
2answers
Compaq Presario freezes at Windows XP screen no task manager
Try to reinstall the windows. This is definately going to hlp.
8/24/2009 11:17:04 AM • Microsoft... • Answered on Aug 24, 2009
2answers
C:\windows\system 32\mshtml.hlp missing.Tells
There is no mshtml.hlp file - http://support.microsoft.com/kb/q190250
Try deleting IE's cache from Tools, Internet Options, click the Delete
Files button under Temporary Internet Files.
Go back to the site where you were saving the 'pics' from and try right
clicking them and choose 'Save Image As'.
8/24/2009 3:34:43 AM • Microsoft... • Answered on Aug 24, 2009
I cannot hear a sound from my computer with Aureal
uninstall drivers and restart the PC. then reinstall drivers.
8/23/2009 7:57:10 AM • Microsoft... • Answered on Aug 23, 2009
Error in script messege while printing downloaded document
so many problem
8/22/2009 9:45:11 AM • Microsoft... • Answered on Aug 22, 2009
Pogo.ui2.awt.e@61ec49
try updating your java.
look at control panel - java click on the update tab and then click on update now. let it update then reboot and try your game.
If you can't find the java under control panel then you may have to instal java from Sun.
http://www.java.com/en/download/index.jsp
Download and run to install. Check for updates and reboot then try your game.
After all that it if it hasn't fixed it, it can just be a java programming error.
If the game is populaur these usually are fixed very fast. If you keep trying every few days it should get the updated file and your game will work again.
8/21/2009 10:56:07 PM • Microsoft... • Answered on Aug 21, 2009
Shucks Guys, I've been on before when my cd.dvd
No that should not be and it sounds like the drive may be bad. Try a paperclip, straighten it out, there should be a little hole on the drive on both of my drives it is just below the door, one drive it is on the left, the other is on the right. insert the paper clip in the hole and push in until the drive opens. You can do this while the computer is on. If the drawer opens and the light is still lit, my vote would be the drive is bad. If the light goes out, remove the paper clip and close the door and see if the light comes back on, if so, again I would vote the drive is bad.
8/19/2009 3:46:40 AM • Microsoft... • Answered on Aug 19, 2009
How to connect wifi with acer laptop
Any wireless router will work. You just have to find the router’s signal on your computer (and sign in to the network potentially).
Your laptop should have a built in wireless card. If it doesn’t, you won’t be able to wirelessly use the internet until you do. I’m assuming you are using Windows.
Click Start at the bottom of the screen, the open your Control Panel. Select the category Network and Internet Connections.
There should be a wireless network setup wizard in there, and will help guide you through the process of setting everything up.
If i am helpful please rate me.
Thank you.
Yboyandrei
8/19/2009 1:06:25 AM • Microsoft... • Answered on Aug 19, 2009
2answers
WINFAX SETUP CLOSES WHEN PHONE NUMBER ENTRY IS BEING PERFORMED
Winfax Pro has been long discontinued software. It also will NOT run properly under Windows XP. That is the problem.
8/14/2009 4:56:21 AM • Microsoft... • Answered on Aug 14, 2009
Microsoft Windows XP Home Edition with Service Pack 2b for PC Logo
48 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Microsoft Computers & Internet
Most Popular Question
excel file corrupt recover
  • Computers & Internet
