20 Most Recent
Ragalta Thermo Electric Hot/Cold Disp - RWC-190 Questions & Answers
How to adjust the temperature
Great question.On the back of the unit you should see two small adjustment screws, You will need a flathead screwdriver (generally) and you can turn these dials to increase or decrease the water temp.This unit may have a plastic panel on the rear that has to be removed first before being able to access these regulators.
What is error code c8 mitsubish heater
The P8 fault can mean many things when it pops up on your Mitsubishi Electric wall controller. The P8 fault is activated when the indoor coil sensor does not change the temperature for a set amount of time after the compressor is (or should be) switched on.
Rival titan floor heater coils don't turn red
Beware when working with electrical equipment. It may cause electric shock.
Check the power supply wires, connections with heating coils. If they are ok then possibly heating coils require replacement.
