20 Most Recent
Cakewalk Music Creator 4 for PC (787537064018) Questions & Answers
My microphone only records on one side. how to i
Your microphone could be a mono or
single channel pickup. Look at the microphone plug and count the isolators
between the metal contacts, if you count one isolator and two contacts you have
a mono microphone, or if you have two insulators and three contacts you have a
stereo microphone. If your computer only has a mono microphone input you may
have to use your line in on your computer. If your volume is weak and you get
noise on your channel you may be required to use a microphone pre amp and plug
the output into the line in jack. Last make sure your computer speaker mixer is
set correctly for stereo.
No signal coming through from
The new version of cakewalk is not compatible with your computer. Can you go back to a previous version that worked for you?
8/8/2010 6:37:48 AM •
Cakewalk...
Answered
on Aug 08, 2010
I just baught a new
Hello
Music creator 3, was made to be used with windows xp, you might want to try right clicking on the shortcut and try running it as administrator, and also if that doesn't help, right click and properties, find the
compatibility page and set it to windows Xp Service pack 3 or similar.
If the program still keeps crashing, it might be best to upgrade to Music Creator 5 which is windows 7 friendly.
http://www.cakewalk.com/products/musiccreator/
1/18/2010 7:16:24 PM •
Cakewalk...
Answered
on Jan 18, 2010
I have sonar 6 le[cakewalk.been recoding for moths
I have tried using different program for recording. It does work for some time but time came when I have also problem met with it. So I uninstall it after clearing all folders etc in program files and in Control Panel, I tried to re install it. PRESTO! it worked with that fine.
Try unistalling if you have the isntaller with you and the Key product.
TNKS
6/21/2009 4:42:16 PM •
Cakewalk...
Answered
on Jun 21, 2009
No sound
Sounds to me like you don't have a bi directional sound card.
It could verywell be your USB driver.
try uninstalling the driver. driver and reboot and let the PC plug and play a generic loaded USB driver.
Possible your sound card or chipset does not support the driver.
goodluck
44hink
2/13/2009 6:06:47 PM •
Cakewalk...
Answered
on Feb 13, 2009
