20 Most Recent Meiko DV80.2 High Temp Door Type Dishwasher Questions & Answers
Meiko DV80.2 error 307
307 Wash tank level sensor defective (short circuit) Check connection, defective sensor, I/O board defective. Per service manual.
10/7/2017 2:11:26 AM • Meiko DV80.2... • Answered on Oct 07, 2017
2answers
Can not start run?
follow this steps and fix it. Merry Christmas 1. No power to the dishwasher Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced. 2. Door switch Replace if defective. Main Control Module / Timer The main control module or mechanical timer controls all the functions of the dishwasher. To check this you will need to find the 2 leads that supply the power to the control. They will be marked on the wiring diagram. They usually come from the hi - limit fuse or the door switch. When the door is latched you should have 120 volts entering the main control. If you do not the problem is not the control. If you do have power entering the control but none of the functions work properly or it does not respond at all you will need to replace main control module. this is easy to replace but not very inexpensive to purchase. Consider the age and overall condition when purchasing this part.
12/26/2014 4:28:44 AM • Meiko DV80.2... • Answered on Dec 26, 2014
Display light ( 3 nos. ) are flashing & can not running.
make this test and fix it. Merry Christmas. Power Supply The main power supply is the first thing to check. Also remove the toe kick and the cover on the power box and check the connections. Also check the 120 volts in p. box. Hi - Limit Fuse This will fail if your dishwasher overheats and occassionally with power surges. This is easy to check, inexpensive and a quick fix. Just check the terminals for continuity ( remember always remove one wire) if you have none replace the hi-limit fuse Door Switch This is the second place to look. Again an inexpensive easy fix. The power comes into the main power box and usually runs to the door switch next before entering the main control module. Replace the door switch if is faulty, use the Multimeter Main Control Module / Timer The main control module or mechanical timer controls all the functions of the dishwasher. To check this you will need to find the 2 leads that supply the power to the control. They will be marked on the wiring diagram. They usually come from the hi - limit fuse or the door switch. When the door is latched you should have 120 volts entering the main control. If you do not the problem is not the control. If you do have power entering the control but none of the functions work properly or it does not respond at all you will need to replace the main control modul l/timer this is easy to replace but not very inexpensive to purchase. Consider the age and overall condition when purchasing this part. Motor The motor may have failed. If the control illuminates on electronic versions the problem may be the motor. To check the motor refer to the tech sheet located behind the console cover on most models, this will sometimes have the ohm reading of the motor. Also check each lead to the metal housing of the motor to check for shorts in the motor. If you do not have the ohm reading specicifications, check for continuity if none replace the motor Make sure the the motor is having power 120v Float Switch If the float switch has failed or is stuck the dishwasher control may not respond. The float switch is easy to check and replace.
12/19/2013 12:40:50 PM • Meiko DV80.2... • Answered on Dec 19, 2013
Meiko UPster U500 Commercial Dishwasher. How to fix meiko upster u 500 error 9
Question edited for clarity, 'make model (what it is)'. https://www.google.com/search?q=meiko+upster+u+500+error+9 ..
3/9/2024 1:45:54 AM • Meiko... • Answered on Mar 09, 2024
Meiko 530 continually filling
Doesn't that suggest there's a faulty sensor?
1/28/2024 10:58:19 PM • Meiko... • Answered on Jan 28, 2024
MEIKO UPster Industrial Dishwasher. How can rectify the meiko d upster dishwadher 118 error
Question edited for clarity. Please spellcheck and Capilitalise. Always include model number. Door Contact Switch error.
MEIKO ECOSTAR & UPSTER Troubleshooting
makewebeasy.net https://image.makewebeasy.net > Document > T... PDF 118. 201. 202. 203. 204. 205. 206. Info & ERR. - No. Description. Possible cause. EEPROM plug-in fault. • EEPROM. - Not present/defective. - Installed ... 2 pages ..
1/28/2024 7:08:49 PM • Meiko... • Answered on Jan 28, 2024
When I start meiko 545D dishwashing machine it showing error codes 907,909,911. What does mean this errors, can anyone help me with the solution.
These are not common errors. Consult with your service department for advice.
12/28/2023 2:13:53 PM • Meiko... • Answered on Dec 28, 2023
Meiko DV 125.2 Commercial Dishwasher. I have error 701 switch off after washing cycle
Meiko Generic Error. It is Conveyor Overload
Operating instructions MIKE 3 - CE
meiko-global.com https://partnernet.meiko-global.com > download Error number 701. Conveyor overload. Basket transport rail is sluggish. The wash items is stuck in the transport mechanism. In such a case the malfunction must ... https://www.google.com/search?q=Meiko+DV+125.2+error+701 ..
11/24/2023 6:12:58 PM • Meiko... • Answered on Nov 24, 2023
Meiko DV 200.2 Dishwasher.I'm getting error 205. Is there any possibility to solve it fast? Is it related to the temperature sensor? Thanks for your help.
Yes according to this link, Booster heater. https://www.google.com/search?q=Meiko+DV+200.2+Error+205 Manual just for fun, but it only show 4 codes and stops ar Error 203. https://static-pt.com/modelManual/MEI-DV200-2_iom.pdf?v=1532002611112 No Service Manual available. Which is odd when it says this washer is for cruise ships! ..
11/22/2023 2:48:08 PM • Meiko... • Answered on Nov 22, 2023
What is the course of meiko dishwasher to say filling errors
no info generic answer --water supply --valve fail -circuit wire damage
11/8/2023 3:11:36 PM • Meiko... • Answered on Nov 08, 2023
Meiko dv120.2 dishwasher info code 124. What does this mean and how is it fixed?
You should contact yourMEIKO Authorized Service AgentIF: •The utensil washer encounters a problem but does not display an error code, OR •An error code appears that is not shown here, OR •The listed action fails to correct the problem. An Authorized Service Agency Listing was supplied with your utensil washer. If you do not have the listing, call 1-800-868-3840 for assistance.
3/8/2023 8:36:31 AM • Meiko... • Answered on Mar 08, 2023
Meiko dish washer Temperature fault rinse error
If you are still experiencing the H0005 temperature fault alarm on your Meiko dishwasher after replacing the PT100 sensors, there may be a problem with the dishwasher's control panel or other internal components. Some potential causes for this problem include:
  • The control panel may be faulty. If the control panel is not functioning properly, it may not be able to read the temperature sensors correctly and generate the H0005 error.
  • The wiring for the temperature sensors may be damaged or disconnected. Check the wiring to ensure it is secure and in good condition.
  • The dishwasher's heating element or other internal components may be faulty. If the heating element or other components are not functioning properly, the dishwasher may not be able to maintain the correct temperature during the rinse cycle.
If you are unsure how to check for and address these potential causes, you may want to consult the user manual for your Meiko dishwasher or contact the manufacturer for assistance.
12/10/2022 3:56:51 AM • Meiko... • Answered on Dec 10, 2022
I have a Meiko hood type dishwashing machine DV80.2. The unit is not starting only displaying Err. 901
Error 901 indicates a communication problem between the CPU board and the double-stacked I/O board in the contactor box. These boards communicate via a CAN bus using an RJ45 / ethernet cable. 1. Check the communication cable (RJ45) to ensure it is operating. 2. Is there an LED lit up on the double-stacked I/O board? If not, then this is the reason for the 901 code. Check for DC voltage at the 3-pin connector on the left side of the I/O board. If voltage is present but no LED lit on the board, replace the I/O board. If there is no voltage, check the power supply board. The power supply board is the square board to the left of the I/O board. 3. Check for cockroaches or cockroach droppings in the RJ45 communication ports. Clean out if necessar with compressed air. 4. Check the CPU board located behind the front panel with buttons on it. Remove the plastic cover over the board. Is there an LED lit up on it? If not, check for voltage at the 4-pin plug. If there is 12V DC and no LED, the CPU board is the problem. If there is no DC voltage at the 4-pin plug, check the power supply board. 5. Check the DIP switches on the I/O board. Make sure only the number 1 DIP switch is turned on. The remainder should be off.
8/20/2022 3:25:45 AM • Meiko... • Answered on Aug 20, 2022
Meiko 80.2 code 111 is there a quick fix to this problem
this code is usually an indication of water leaking internally where the motors are located. Needs to be found and stopped.
4/17/2022 6:46:21 AM • Meiko... • Answered on Apr 17, 2022
Meiko do 80 turn on machine then machine turns off also water in display panel
Replace the display panel and fix the leaks.
1/11/2022 7:37:20 AM • Meiko... • Answered on Jan 11, 2022
2answers
Meiko dishwasher. Do I have an eeprom problem?
sounds like it could be a defective cylinoid switch...this will not allow water to flow properly through the machine....this is located at the water connection....try replacing and reconnect water...good luck
9/13/2021 9:26:11 AM • Meiko... • Answered on Sep 13, 2021
Model fv 40.2. What does error code 907 mean?
try asking your local dealer
4/23/2021 7:03:33 AM • Meiko... • Answered on Apr 23, 2021
MEIKO 545D Error codes 907 ,917 - Meiko Dishwashers question
Meiko ecostar 503 f error 907
9/13/2019 4:40:09 AM • Meiko... • Answered on Sep 13, 2019
Meiko DV80.2 High Temp Door Type Dishwasher Logo
6 questions posted
Top Meiko Dishwashers Experts
john h
ADMIN Andrew
ADMIN Andrew
Robbie Goodwin
Are you a Meiko Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Meiko Dishwashers
  • Meiko Dishwashers
Most Popular Question
meiko dv80 2 error 307
  • Dishwashers
