20 Most Recent Jet Tech Systems F-14 - Multi-Purpose Ware Washer, Compact Counter " Questions & Answers
a plug can be warm. if it is hot to the touch, stop using it and have the machine checked and the receptacle check by a qualified technician.
Jet Tech Systems... | Answered on Sep 02, 2014
for models equipped with a drain pump;
verify that the pump is not clogged. if it hums during the fill cycle or rinse cycle then something is lodged inside. If it doesn't then it needs to be replaced.
for models without the drain pump;
something is interfering with the water flow. when the stand pipe is removed, the tank should empty in about one minute.
Most Jet-Tech dishwashers has one adjustable rinse thermostat and one fixed wash thermostat. The wash thermostat can be substituted with an adjustable thermostat. Location depends on the model. F-18 are located on top. F-22 are located under next to the wash tank. Search by part number or description
Jet Tech Systems... | Answered on Jul 15, 2014
On the F-14, the booster thermostat must be satisfied. The rinse thermostat must work properly and or the rinse heater. follow the diagram. This kind of troubleshooting is done by qualified technician. Remember to unplug the unit before opening the panels. It could be just a burnt wire on the rinse booster heater connection.
The detergent system on the Jet-Tech machine are all very similar. Near the solenoid valve under the machine, beside the drain connection, there are two wires, one red and one blue. Those wire will run the detergent pump when the machine calls for water. Two tube are attached to the pump. when looking at the pump from the front or clear plastic can be seen, the tube on the left (arrow going up) is connected to the container with the detergent. the tube on the right (arrow down) is connected to the back of the unit to inject the detergent into the tank. Some precaution should be taken to assure that the connections are tight and not leaking. if the tube shows signs of crystals inside, it should be replaced as the detergent as crystallized within. Search by part number or description
If the machine will fill on its own when it is empty then the rinse cam on the timer is defective
Jet Tech Systems... | Answered on Dec 29, 2013
No idea as i would either make my own or go to general store in alicante and ask the nice man if he has anything that would do the job if the original parts were not available
Jet Tech Systems... | Answered on Dec 25, 2011
www.jet-tech.com/products/F-18DP/f18_tech_manual.pdf
Copy and paste that link into your internet address bar or type it in.
That is your manual
Jet Tech Systems... | Answered on Sep 22, 2010
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Jet Tech Systems... | Answered on Sep 01, 2010
If this is a common problem then ring the manufacturer, if not you will need to have it replaced.
Jet Tech Systems... | Answered on Aug 03, 2010
since i see no brand or make mentioned , I could never begin to guess suggest you call a local repair service
Dishwashers | Answered Yesterday
Hi, I had the problem on an Omega DW420XA. There are 3 things you need to do before starting on the whole replacing parts palava: 1. Detach the exhaust pipe (usually a grey crinkly pipe) from the sink u-bend. Stick a screw driver into the ubend connector and make sure there is no gunk there blocking it up. 2. Remove the filters at the bottom o the machine and give them a good clean. Stick your fingers into the sump where the water collects and get every last little piece out. You may have to twist your finger into the space around the impeller. 3. Pull the dishwasher forward from under the bench and tilt it forwards. Some water may run out, but this is causing the sensor to think it is not discharging. Note you may have to free the power, inlet and outlet pipes from getting stuck as you pull it forwards. With any luck it will now run (mine did).
Dishwashers | Answered 2 days ago
If it is a high efficiency dishwasher, similar to my Bosch, you have to make sure to add the rinsing agent, such as Jet Dry. These washers will never dry off the dishes without that rinse agent. In addition, I find that the best cycle is actually the shortest cycle. I get a much better results from the 50 minute cycle than I do from even the 2 1/2 hour cycle.
Tip
How to find appliance model numbers
<p>When trying to troubleshoot or purchasing parts for your appliance the model number is the key to doing so. Each model may have different part numbers and or different troubleshooting techniques. They may also have a different service manual. The model number that is on your customer manual is just a generic copy of many models that exist and can not be used for the information that is needed.<br /> <p>Below you will find a video procedure that will show you how to find your entire model number. You can bring it up in either picture or video format.<br /> <p>For finding your appliance model number Click on the link <a href="http://www.repairclinic.com/Appliance-Parts">http://www.repairclinic.com/Appliance-Parts</a><br /> <p>Just to the right of the "<b><i><u>search</u></i></b>" tab click on "<b><i><u><span>help me find my model number</span></u></i></b>"<br /> <p>Just click on the model of your choice In either video or image<span> </span>presentation<br /> <p>Please consider giving us a 4 thumbs up for our procedure.<br /> <p> <b><i><u>Thank you for using FixYa!</u></i></b><br /> <p> <br /> <p><img src="kdrake84_0.jpg" /> <img src="kdrake84_1.jpg" /><br /> <p> <br /> <p><span></SPAN><span><br></SPAN> <p>
on Apr 17, 2019 | Dishwashers
Jet Tech Systems F-14 - Multi-Purpose Ware Washer, Compact Counter " Logo
1 questions posted
Top Jet Tech Systems Dishwashers Experts
Robert Marsolais
Robert Marsolais
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jet Tech Systems Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Jet Tech Systems Dishwashers
Most Popular Question
part number f 14 dishwasher timer
  • Dishwashers
