20 Most Recent
Jet Tech Systems F-22 - Dishwasher, Door Type, high temp. w/built-in " Questions & Answers
The water temperature get to hign
The F-22 wash tank heater is controlled by a thermostat that opens or close a relay located in the control panel on the right. the thermostat is located inside the machine next to the wash tank. the thermostat is fixed position and can not be adjusted. the temperature should be 170F max. The thermostat has a bulb attached by a wire. this wire is actually a tube and the bulb is filled with an oil that expends when heated. the bulb is inserted in a cavity in from of the wash tank. You can access this by removing the front panel. If the bulb is not in the cavity, it will produce alot of heat. if the "wire" is broken or just simply the thermostat has become defective than it should be replaced.
Search by part number or description
Ready light does not come on and unit continues to heat after cycle complete. Rinse temp stays at 205 F.
Ready light is there to tell you the thermostats have cycled off, rinse temp first and then wash temp after. if the wash temperature is low (below 160F) then we need to look at either the thermostat for wash or the heather is bad. if bot the temperatures are ok then it is just the light that is bad. If the rinse temperature shows 205F on analogue thermometer, a secondary reading is necessary with an external thermometer on the booster it self. These analogs thermometers are not so accurate.
Plug getting hot
a plug can be warm. if it is hot to the touch, stop using it and have the machine checked and the receptacle check by a qualified technician.
The unit is overflowing and will not drain
for models equipped with a drain pump;
verify that the pump is not clogged. if it hums during the fill cycle or rinse cycle then something is lodged inside. If it doesn't then it needs to be replaced.
for models without the drain pump;
something is interfering with the water flow. when the stand pipe is removed, the tank should empty in about one minute.
Tech manual
Most Jet-Tech dishwashers has one adjustable rinse thermostat and one fixed wash thermostat. The wash thermostat can be substituted with an adjustable thermostat. Location depends on the model. F-18 are located on top. F-22 are located under next to the wash tank.
No heat from F-14
On the F-14, the booster thermostat must be satisfied. The rinse thermostat must work properly and or the rinse heater. follow the diagram. This kind of troubleshooting is done by qualified technician. Remember to unplug the unit before opening the panels. It could be just a burnt wire on the rinse booster heater connection.
We have a model F-18
www.jet-tech.com/products/F-18DP/f18_tech_manual.pdf
Copy and paste that link into your internet address bar or type it in.
That is your manual
Drain pipe broken
If this is a common problem then ring the manufacturer, if not you will need to have it replaced.
Can't get dishwasher out from underneath the counter
Question edited to move it from Computers to Dishwashers.
Is there by any chance a floor tile 4" out from the dishwasher front? If so, try lifting the front with a crowbar or long screwdriver.
Did you disconnect, inlet hose, drain and power? They may have been installed tight, or clipped.
4/19/2024 6:24:59 PM •
Dishwashers
Answered
16 hours ago
HOW TO REPAIR A HOLE IN MY DISHWASHER
It depends upon the material you are trying to repair but Araldite or any good quality two part epoxy will suffice to fill the hole.
Ensure the area is dry and clean then build up the repair . Larger holes will require multi additions of epoxy.
4/15/2024 10:01:23 PM •
Dishwashers
Answered
on Apr 15, 2024
WINTERHALTER MODEL MTR3 GIVE ME ERROR 22.2 AND ERROR 12.1
These error messages both point to a sensor problem.
Error 12.1
This error is related to the boiler temperature sensor. Consider the following:
Look for a short circuit in the sensor. Inspect the cables and plugs for any issues.
Ensure the sensor is correctly connected.If needed, replace the boiler temperature sensor.
Error 22.2:
This error pertains to the tank temperature sensor. Possible causes include:
Short circuit in the sensor.
Cable failure or plug failure.
Sensor not properly connected.
You may need to check the sensor wiring, connections, and replace the temperature sensor if necessary.
4/3/2024 6:11:13 PM •
Dishwashers
Answered
on Apr 03, 2024
What year is this Kenmore dishwasher Model # 665.15831791 made?
The date of manufacture is determined by the SERIAL NUMBER on the appliance. This dishwasher was manufactured by Whirlpool. The following link explains how to determine when it was manufactured:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
The serial number is usually located somewhere around the door opening. The first two numbers in the serial number identify the WEEK it was manufactured (52 weeks in a year). The second DIGIT in the serial represents the YEAR it was manufactured.
If you have difficulty determining the manufacture date, please post back with your serial number and I will assist you. I hope you find this information helpful.
3/12/2024 6:43:46 PM •
Dishwashers
Answered
on Mar 12, 2024
