20 Most Recent
Roxio Easy DVD Copy 2 Premier Full Version for PC Questions & Answers
Dvd software won't install in vista computer
you could try dragging the files from the roxio installation disc onto the desktop. or if downloaded then just go to the setup file. when you find the setup file right click on it then go to properties - compatibility and then click on run this program in compatibility mode for: xp then further down click on the run this program as administrator.
Please let me know if this works and give me a fixya rating if it does.
Thanks
Roxio creater starter 12.1.0.439
If you are experiencing the certificate file message or missing tabs in your Roxio software, please perform a manual update of your anti-virus or security software and reinstall the Roxio Creator Starter. You can perform a manual update by launching your anti-virus or security software and using the Update option.
Prior to reinstalling, it is strongly advised that you temporarily disable your anti-virus and security software and any unnecessary background processes to ensure a smooth install.
I have tried to install
Please go through below link and check what are you missing.
http://img.roxio.com/enu/products/creator/2011/system-requirements/c2011-system-requirements.html
How do I burn multiple slide shows to DVD using Roxio 2011
Create the multiple slide shows and store them in a directory that you have created on your hard disk just for those slide shows. When all the slide shows are present in that directory, start Roxio, use the Add Files function and go to that directory and select all of the files you want on the DVD. Name the DVD to something that indicates what is on it and start the Create/Burn to make your DVD.
