20 Most Recent Hobart Undercounter/Lxi Warewasher 24"W x 26-3/4"D x 33-3/4"H With Detergent Pump, Hobart Questions & Answers
My lxi-h won't draw rinse aid through the pump
You need to replace the squeeze tube on the rinse aid pump
4/2/2014 10:27:48 AM • Hobart... • Answered on Apr 02, 2014
0answers
Hobart AM15-1 Low Temperature Dishwasher. Techs question. I just replaced main board and relay board but now getting a E1 error code, curious if anyone knows what it is?
Question edited for clarity. Error codes should be on the rear label according to the Technical Manual https://www.partstown.ca/modelManual/HOB-AM15T_spm.pdf There is no E1 error code for that machine and is is suggested that the display may be faulty. https://www.google.com/search?q=hobart+am15+e1+error+code The only reference to E1 is here, for the AM-16 and an electrical 'type'. https://www.hobart.ca/wp-content/uploads/pdfs/warewash/AM16-BAS-Base-Electric-CF48568.pdf For LXi machines Drain and fill error messages are displayed as E0, E1, E2, E3, E4, E5, E6 or E7. In all cases, the dishwasher will terminate current cycle operations, turn off all heat sources and display the message until the OFF button is pressed. (A power drain will not occur when turned off.) (See Troubleshooting.) If problem persists, contact your local Hobart Service Office Phone Hobart Support. there are no Hobart Techs here, just me as caterer, career long Hobart user and Expert finder of information. Or try JustAnswer dot com. ..
4/16/2024 5:19:38 PM • Hobart... • Answered on Apr 16, 2024
Problem on hobart ecomax 602-10
1/4/2024 2:04:53 PM • Hobart... • Answered on Jan 04, 2024
Hobart Dishwasher CL44E showing display PROBE ERROR-WSH PW DR.
To me the Error is telling you Probe Error - Wash - Power - Drain CL & CLe Series Dishwasher Display Codes Below are common codes that display on Hobart CL and Cle Series Dishwashers:
  • Door(s) Open - This displays if one or both doors are open. Close all inspection doors.
  • Clear Conveyor Jam - The code appears if there is a jam. Remove the rack from the machine. Then, press START and rerun the rack.
  • Probe Err - TANK - Check if the lower float assembly in the displayed tank isn't visibly damaged and that the proper amount of water is covering the lower float in the tank.
  • Probe Error - FnlRns - Make sure the supply water valve to the rinse booster is open.
More here and a video https://www.google.com/search?q=Hobart+PROBE+ERROR-WASH+PW+DR https://www.hobart.com.mx/pdf/FichaTec/F-40196.pdf Service Manual https://hvac-talk.com/vbb/attachment.php?s=219f76d9e796c2e5f1c5fef6b79fad9d&attachmentid=830275&d=1639784925 from here https://hvac-talk.com/vbb/threads/2234701-Hobart-Service-Manuals ..
11/14/2023 10:10:01 PM • Hobart... • Answered on Nov 14, 2023
Hobart FT1000 Flight Type Commercial Dishwasher. The final rinse is not showing the temperature number.
Probably the temperature sensor, but do you want to risk $227 on a guess? It is a commercial machine, just call your local service tech. https://www.google.com/search?q=hobart+dishwasher+ft1000+service+manual+pd It is NOT a common fault https://www.google.com/search?q=hobart+dishwasher+ft1000+rinse+temperature+blank ..
8/17/2023 5:44:06 PM • Hobart... • Answered on Aug 17, 2023
2answers
Hobart AM-14 dishwasher is constantly filling with water.
Question edited for clarity and written English. It is a professional machine, you have it serviced professionally by your local Hobart Service Centre and claim the repair against your expenses. The machines are way beyond the capabilities of someone that can just buy parts online. It is either incorrectly wired or the control board or relays are are failing / failed.
8/16/2023 10:14:41 PM • Hobart... • Answered on Aug 16, 2023
2answers
What is wrong with Hobart dish machine says check water level
1.Loss of water pressure due to pump obstruction. Check for any obstruction at the pump intake. 2.Strainers clogged causing inadequate water supply to pump. 3.something may be inhibiting free movement of the low water float; remove any foreign object from around the low water float or its magnet.
4/13/2023 3:03:33 AM • Hobart... • Answered on Apr 13, 2023
Hobart AM14, the float assembly keeps failing. We are on our 4th one. Ruled out heat, electrical and we also replaced the main board. Anyone experienced this before?
It sounds like you're experiencing recurring issues with the float assembly on your Hobart AM14 dishwasher. You've already ruled out potential causes such as heat and electrical issues, and have even replaced the main board to try to resolve the problem. However, you're still encountering failures with the float assembly, which is unusual given that the dishwasher has been in use for 18 years without any prior issues with the float. Without additional information or an on-site inspection, it's difficult to pinpoint the exact cause of the float assembly failures. However, some potential causes could include:
  1. Damage or wear to the float assembly parts: Over time, the float assembly parts may become worn or damaged, which can affect their performance and lead to failures.
  2. Water quality issues: Poor water quality, including high mineral content or excessive amounts of chemicals, can damage the float assembly or cause it to malfunction.
  3. Improper installation: If the float assembly is not installed correctly, it may not function properly and could fail prematurely.
  4. Inconsistent usage: If the dishwasher is not used consistently or is used excessively, this could put strain on the float assembly and cause it to fail more frequently.
It's important to work with a qualified technician who has experience with Hobart AM14 dishwashers to diagnose and resolve the issue. They can inspect the dishwasher, including the float assembly and other components, and identify any potential causes of the failures. From there, they can recommend the appropriate course of action to resolve the problem and prevent future failures.
4/10/2023 7:40:21 PM • Hobart... • Answered on Apr 10, 2023
2answers
Hobart 130363 Commercial Dishwasher. Where is the fuse on the Hobert 130363 please
The cooling fan relay for the Alfa Romeo GTV6 1986 is located on the firewall, just behind the battery. The part number is 6043313.
3/2/2023 1:10:59 AM • Hobart... • Answered on Mar 02, 2023
Hobart AM15-1 dishwasher. Good morning, why does 'DP' appear on the display and immediately after that it starts washing and does not show the temperature on the display?
Question edited for a lot more clarity. All question need FULL 'make model (what it is)'. Question moved from laundry Washing Machines to Hobart Dishwasher category. 'DP' or 'PD'? PD is not an error code. It shows that when it draining water out shortly after power-up and when shutting down. If it seems to be showing "PD" longer than usual, it means the dishwasher's control circuitry believes there is still water in the tank, due to a faulty water level probe, most like the one under the lift-out screen. It has a plastic body with a metal probe coming out the center. There is also a dual probe at the rear of the machine, but I believe the dishwasher uses the front probe to determine when to stop draining the machine during "PD" - most likely meaning "Power Drain" or "Power Draining". If you are not seeing any E- codes (E1, E2, E3, etc.) then these water level probes are likely just fine and the "PD" is appearing normally, as it should during draining conditions. Manual just for fun. https://www.partstown.ca/modelManual/HOB-AM15T_spm.pdf ..
2/24/2023 5:49:27 PM • Hobart... • Answered on Feb 24, 2023
Hobart FT900S E513 Error Code. Anyone know what it means and how to resolve?
E513 =Final rinse temp probe is open circuit. Active when temp read is less than 32°F.
2/24/2023 1:37:30 AM • Hobart... • Answered on Feb 24, 2023
Hobart am15 AH code on start up
If your Hobart AM15 dishwasher is displaying an AH error code on start up, it usually indicates that there is an issue with the booster heater. AH stands for "Booster Heater Circuit". Here are some troubleshooting steps you can follow to resolve the issue:
  1. Check the booster heater temperature sensor. It may be dirty or faulty, preventing the booster heater from functioning properly. Clean or replace the temperature sensor if necessary.
  2. Check the booster heater element for continuity. If the element is broken, it will need to be replaced.
  3. Inspect the wiring and connections between the booster heater and the control board. Loose or damaged connections can prevent the booster heater from functioning properly.
  4. Check the booster heater relay on the control board. If the relay is faulty, it will need to be replaced.
If none of these steps resolve the issue, you may need to contact a professional technician to diagnose and repair the problem.
2/15/2023 5:47:37 AM • Hobart... • Answered on Feb 15, 2023
Hobart AM14. It is filling and going into wash cycle properly but rushes through cycle in about 5 seconds total. Pump starts. Tank heats. Float switch seems good.
It is possible that the timer or control board is malfunctioning, causing the machine to rush through the wash cycle. You may want to consider checking and replacing these components if necessary. It is also important to ensure that the wash arm and nozzles are not clogged or blocked, as this can affect the wash cycle's effectiveness.
2/14/2023 11:47:46 AM • Hobart... • Answered on Feb 14, 2023
Hobart Undercounter/Lxi Warewasher 24"W x 26-3/4"D x 33-3/4"H With Detergent Pump, Hobart Logo
8 questions posted
Top Hobart Dishwashers Experts
vince
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Hobart Dishwashers
  • Hobart Dishwashers
Most Popular Question
hobart dishwsher strange lint like fiber
  • Dishwashers
