20 Most Recent
Generic Memory (RXD639) Serial ATA Controller Questions & Answers
Installing a IDE to SATA converter adapter
I have successfully connected a older. 20 GB drive to a computer with a 2. sata connection on the mother board.
Buy trial and error I found that connecting a power cable to the converter and the hard drive was the only way to get the Bios To recognize the drive.
Done sucessfuly with a 40GB drive as well, Set drive to master.
How do you block ads from Opera Browser
1.Firstly, open your opera browser
2. Open Tools ->Advanced->Blocked content
(whichallows you to block webpage content from the website)
3 A dialog box will appear and you need to list website or part of website to be blocked.
example:
http://pagead2.googlesyndication.com/*
http://ads.*
http://imgserv.ad*
hope this help
I installes a coxeant modem but i need the drivers
Try using
this link to get the drivers for your modem, deppending on the system you have.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
How to install memory on ecs G550 laptop can only
There are two memory slots which support PC2700/333 Mhz memory, maximum 1024 per slot.
ECS suggests using identical/matched pairs of chips from the same manufacturer for their units.
In most laptops there is an access panel which when removed gives you direct access to the memory chips for replacement. I couldn't find a mainboard diagram for this unit so I am unable to see if the memory slots are adjacent on the board but there is little reason they shouldn't be. You should be able to access both slots once the proper access panel is opened.
This is the website page for direct contact with ECS tech support if you have any further questions: http://www.ecsusa.com/ECSWebSite/Support/TSSRequest.aspx?CategoryID=3&MenuID=19&LanID=0
Mac books have a key chain to remember passwords... do regular pc
if you are talking about websites, then using firefox allows you to remember passwords( via tools --> options --> then security; saved passwords)
whenever you go to a website and enter in a password, it will ask if you want to add, then on top of that you can enable a master password to protect that information from showing when you immediately access the particular site.
Error 25099 unzipping core files failed i was
Make sure that you remove all previous instances of Java on the system and start the process again as the compressed Java file has an error. If the process fails again after you have removed allinstances of Java from your system then try downloading and saving the file instead of installing dynamically via the internet. Then run the installation. This should work OK.
In my computer audio drive is not working
You say your audio drive--I don't know what you mean by that. I assume your sound card (whether it's part of the motherboard or a separate card) is not working.
In this case, I would first check to see if your sound has actually been turned off. Check on sounds in the control panel.
If you try to play system sounds from within the control panel and the little right arrow that you click to test stays gray, then you need to reinstall the sound drivers. Get them from the manufacturer of the computer or the motherboard manufacturer.
Computer DVD &DVD writer wont play can you
You need a replacement DVD player or you can get a DVD RW (Readable Writable).
You can find them very cheap on ebay but I recommand you go to a store and purchase one.
Thanks for using FixYa
Have A Nice Day
How to store files onto my external hard drive
saya punya hd maxtor 30gb pada posisi jumper master g bisa dideteksi bios,tapi pada posisi slave terdeteksi 41 gb.yang jadi masalah hd tersebut g bisa diinstal ulang atau diformat! mohon bantuannya agar hd saya bisa dipakai lagi.thanks
How to install video card to computer
if you want to connect the hardware with your computer then u need to install this card in appropriate slot. like if your have AGP VGA then install it in AGP slot. every normal motherboard have a single slot for VGA installation and it could be AGP or PCI express.
and if you want to install the drivers for the VGA then you have to inform us the model and company make.
