20 Most Recent Maytag Precision Cooking System Electric Range" Questions & Answers
Take the front glass panel off my range to clean between the glass
This should be a double paned insulated glass, you will need to take the door apart to get behind the glass.
1/27/2015 1:17:48 AM • Maytag Precision... • Answered on Jan 27, 2015
Maytag MER5552BAW stopped working while cooking last night.
othing Works, or the Oven / Range / Stovetop Works Only At Certain Times: 1. Home breaker flipped or the fuse blown? Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary. 2. Power cord plugged in? Grab the plug and wiggle to determine a good connection. 3. Power cord damage? Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires. 4. A clicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board. 5. 6. Even a bad relay door switch will hinder your oven from operating. If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse ++++ Oven Control Board The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven. Relay board: Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT. fuse location oven fuse_ranger_17-undefined-undefined-0.jpg fuse testing oven fuse-undefined-undefined-2.jpg fuse module with words-undefined-undefined-5.jpg oven relay board dacor-relay-board-92028-ap3851203_01_l-undefined-undefined-9.jpg
3/17/2020 5:29:34 AM • Maytag Cooktops • Answered on Mar 17, 2020
Maytag glass cooktop timer button broke through and now it doesn't work. Help please.
Use this link for answers to all your cooktop issues.
3/15/2019 1:17:10 PM • Maytag Cooktops • Answered on Mar 15, 2019
Maytag MER5552BAW stopped working while cooking last night. Was using the cooktop and the oven and all seemed to turn off at once. May have had water spill into on of the burners.
Go to your electrical panel and check the circuit breakers. If one is tripped it will be in a halfway position. switch off then on. If it keeps tripping you may have to call a repair man.
2/10/2019 5:43:22 PM • Maytag Cooktops • Answered on Feb 10, 2019
New Maytag MGC7430 gas cooktop leaks gas when lit
First it could be leaking from the control knob when it is on . There could be a leak at the base off the burner letting out gas or on the burner line . You need to get back on to your installer or where you purchased the cook top . This basic gas fitting leak detection .
6/19/2017 1:56:49 PM • Maytag Cooktops • Answered on Jun 19, 2017
My Maytag glasstop burner popped loudly and I smelled burned wires. Water overflowed from a pan on the cooktop. Can it be repaired?
Sure. The wiring harness can be repaired or replaced as well as any damaged components.
8/29/2016 3:17:35 PM • Maytag Cooktops • Answered on Aug 29, 2016
0answers
I was wiping out my oven. It sparked. Now nothing
Tammy have you checked the circuit breaker at the electrical panel of your home. Do the panel lights come on? If they do and the rest is off then it will need service.
10/13/2013 9:37:21 AM • Maytag Cooktops • Answered on Oct 13, 2013
Oven panel displays F1
call or e-mail the company or the manufactor they can help.
3/11/2013 10:56:55 PM • Maytag Cooktops • Answered on Mar 11, 2013
Maytag no oven display and no oven control
You will need to replace the display assembly, the oven control board is part of it and it is burned out.
5/22/2012 11:19:35 PM • Maytag Cooktops • Answered on May 22, 2012
2answers
I have a Maytag performa Kitchen stove and all 4
is it gas?
if it is gas i would strongly suspect the spark module
12/20/2011 1:02:47 AM • Maytag Cooktops • Answered on Dec 20, 2011
I have a maytag gas stove model #MGR5775QDQ serial
You have a bad ignitor to your oven. Part number you should replace is 12400035. This should fix this problem. Just because it glows does not mean it work correctly, it works off of the flow of electricity rather then the glow of the ignitor.
Ignitor How to test How to change ignitor
Good Luck I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
8/29/2011 10:24:55 PM • Maytag Cooktops • Answered on Aug 29, 2011
2answers
The electronic lighter will not quit clicking.
Hello, Thank You for using FixYa. I will be helping you today. Did you clean the cook top or spill something? If the switches get wet they will click untill it drys out. If not then one of the switches failed and would need to be replaced. Its the switch that sits on the burner valve.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
7/19/2011 10:39:40 PM • Maytag Cooktops • Answered on Jul 19, 2011
My electric igniter keeps sparking
Hello, Did you clean the cooktop recently? Sometimes water or cleaner can get into the spark switch causing it to spark untill it dries out. The same if a boiling pot spills. If none of those happened one of the burner switches is bad.
6/7/2011 11:55:30 PM • Maytag Cooktops • Answered on Jun 07, 2011
The surface light on my mothers stove stays on and
Here is a tip that I wrote about why the hot surface indicator light will not go out...
Oven Hot Surface Indicator Light stays on
heatman101
1/18/2011 6:33:56 AM • Maytag Cooktops • Answered on Jan 18, 2011
Maytag Precision Cooking System Electric Range" Logo
1 questions posted
Top Maytag Cooktops Experts
Paul Carew
Stan Ford
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Maytag Cooktops
  • Maytag Cooktops
Most Popular Question
front glass panel off range clean
  • Cooktops
