20 Most Recent
Frigidaire Gas & Electric Stove/Oven/Range /Cooktop Ultimate Griddle Questions & Answers
Why is door locked and will not self-clean?
Hey Kimberly, thank you for your inquiry!
I understand that the door on your Frigidaire range is locked and it will not start a self-clean cycle, it is also displaying an error code of "F91". The "F91" error code means that the door has exceeded maximum oven door unlock time. This means you could be experiencing an issue with your door latch, control panel, or a miscommunication within the range. To clear out a miscommunication within your range you need to disconnect power from it for at least ten minutes. I hope that this information is helpful to you. -Matt
Frididaire electric stove the oven has stopped working
Good Afternoon Friend, thank you for allowing me to assist you!
I understand you are experiencing an issue with the oven of your Frigidaire range. May I have your model number please? You can normally locate the serial tag (which provides your model number) in the storage drawer, on the right side. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? Do the burners/elements work? With this information I can assist you better in pinpointing the problem.
Meanwhile, let's try resetting your range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn your range on. If resetting the power does not correct the issue, could you please advise me if the issue continues or provides an error code. Thank you! -Z
How to change the temperature display from Celcius to Farenheit
Hello Friend, that's a great question!
Please follow the steps below to change the temperature to Celsius to Fahrenheit on your Frigidaire range, FEF366CCA.
·Press BROIL. "-" appears in the display.
·Press and hold the UP arrow until "HI" appears in the display
·Press and hold BROIL until F or C appears in the display.
·Press the UP arrow or DOWN arrow to change F to C or C to F.
·Press any control pad to return to normal operating mode.
Hope this helps! - Z
I was trying to on oven all of a sudden massage appear f10
Hi khan, this is Z! Thank you for your post!
Typically error code F10 indicates that your range has detected an issue with the runaway temperature (overheating). Try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. I suggest waiting approximately ten minutes and then turn on your range. If the error code does not clear, I would recommend contacting a professional technician to assist you in the exact diagnosis and repair of your range. Most likely the EOC (electronic oven control) will need replacing. Hopes this help!
Meat does not brown in gas oven
Hello - Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately two minutes and turn the range back on. Select a normal bake cycle and if issue continues then the unit may possibly have either a faulty element, bad communication error with the main control board, oven sensor, or mechanical thermostat. I strongly suggest contacting a professional to move forward accurately. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage.
Bad Electric Cooktop Dual Element Switch
Our Frigidaire Gallery electric cooktop dual burner would not work when either the single or double mode was selected. I did not have the electrical schematic available to use for troubleshooting the switch and initially was not certain if the switch or heating element was bad.
In thinking about the situation, I deduced that the problem was most likely the switch being bad as it was highly unlikely that both elements of the dual element burner would be bad at the same time. I ordered a new switch, received it a few days later, and replaced it in about 25 minutes. Upon turning power to the cooktop on and trying the new switch, both elements of the burner worked as expected.
Our Frigidaire Gallery induction cooktop is 'locked'. How to unlock?
Press and hold the keypad with the padlock icon until you hear a beep. This should be about 3 seconds. This will toggle the lock on and off. I used the documentation for the Frigidaire FGIC3067MB to check this. On this model, the lock keypad is to the left of the Keep Warm keypad. https://www.frigidaire.com/Kitchen-Appliances/Cooktops/Induction-Cooktops/FGIC3067MB/ . The manual is here: http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318205604en.pdf . The control panel is shown on page 5 and the lock function is shown on pages 6 and 9.
I hope this helps.
Burner won't turn off. stays in simmer mode
Good Afternoon Judy, thanks for your post!
From what you have described the burner on your Frigidaire cooktop will not shut down and continues to run in simmer mode. I would suggest performing a reset on your cooktop and you can do that by disconnecting power from your cooktop for at least ten minutes. If that does not help alleviate your situation you may need to have a burner switch or control panel replaced and that is not a simple DIY job. If any electrical components need to be replaced I would recommend contacting a professional technician for proper repairs to be completed. This will help you avoid any unnecessary part purchases. I hope this information is helpful. -OOS
