20 Most Recent J4constructioncom Black & Decker 14.4V Cordless Dustbuster Cyclonic Handvac LB152964 Questions & Answers
omg. Not clear question. What model ?
Vacuums | Answered Yesterday
Try a warmed up pin or paperclip the plastic may not have been punctured when it was unmolded during the manufacturing process or return to the store for another one.
If you don't have the User Manual, find one here:
https://www.bissell.com/support/user-guides
Assuming you are talking about the roller brush most likely a belt problem. If you can spin it with your hand with no resistance then your belt is broken or very lose. Either way get another belt, they are easy to replace yourself. Now if you are not talking about a vacuum then who knows but I am assuming you are talking about a beater bar.
If it isn't not turning, doesn't that mean that it IS turning?
Some are easy and others hard.
This video may help you.
https://www.youtube.com/watch?v=Hwafej5N2ZY
Fixya does not sell vacuum motor brushes.
Vacuums | Answered 3 days ago
you are plugged into the wrong place lol
Vacuums | Answered on Apr 20, 2019
I had the save problem with my 3400 series.
The first time i was able to let it dry and it worked alright (48 hours).
The second time even this did not work.
If you remove the screws on the bottom of the unit. There are about 10 and pull it down, you will see the sealer assembly and a small circuit board in the middle.
Trace the wires from the drip tray, there are three of them, red white and brown, to the small white plastic JST connector on the small circuit board. Pull said connector gently to disconnect it.
The unit will function perfectly now, although it will no longer have a drip tray sensor of any sort it will function every time all the time.
All in all this took me about 10 minutes.
Thanks!
You can use a set of composite cables (red/white/yellow).
sadly we have no idea what you did or didn't do wrong as have never seen one of them . i always just use scissors to cut hair out of the brush roller myself , no dis assembly required
Vacuums | Answered on Apr 19, 2019
Ususally this is caused by a forein object has gotten hung in the suction impeller attached to the motor. the noise flucuates due to the housing flexes with the movement of the handle and rod. the housings are usually made of plastic and something very small can easily get stuck in it and stay for a very long time. The vacuum needs disassembled and the forien object removed from the fan housing...
Hope this helps
Sincerely
Roger
Vacuums | Answered on Apr 18, 2019
What the????????????????
mabe you should earn codes but i will give ya a few here they are explorer - 100 gems ngkidsrox - 1000 gems discovery - 1000 gems AJBDAY3 - 3rd Birthday Cake bemybuddy - 500 gems AJHQ3000 - 500 gems 10million - 10 Million Banner
ngexplorer - 1000 gems
drawing - 500 gems
hooot - 500 gems
alphas - 500 gems
kangaroo - 500 gems
koala - 500 gems
dolphin - 500 gems and thats all the codes you will need
J4constructioncom Black & Decker 14.4V Cordless Dustbuster Cyclonic Handvac LB152964 Logo
1 questions posted
Top J4constructioncom Vacuums Experts
Marvin
Marvin
JoeVacs
Are you a J4constructioncom Vacuum Expert? Answer questions, earn points and help others
View Most Popular
  • J4constructioncom Vacuums
Most Popular Question
new swifter only one spray nozzles
  • Vacuums
