20 Most Recent
Simrad Rpu160 Reversible Pump 21118237 Questions & Answers
Testing Simrad Autopilot RPU160 Reversible Pump (21118237)
yes, hook it to 12V it runs, reverse wires it runs opposite
it will spit oil, watch out!
shoulda coulda left it in place and tested with jumper cables or battery
if pump is bad
1 find out why your boat eats pumps
2. call me, i have it in stock for less than you paid before (most likely)
3. you can replace the electric motor without disturbing the hydraulics!!!
847-746-0100
My simrad ca44 keeps turning itself on and off
This is almost always a power supply issue. Check and clean your positive and negative connections. Although the link below is for car batteries, the principles are the same.
If that gives you no joy, check the plug and socket of your unit. It doesn't take much corrosion to render an electronic device inoperable.
Hope this helps.
-Steve
How to Clean Car Battery Terminals
