20 Most Recent
Furuno 1850w/Nt Gps Chartplotter C Map Nt Charts Questions & Answers
Data cards for Fununo 1850w
Furuno just stopped producing these models about a year ago. They use a special chart card. You can still purchase the cards from Navionics or C-map if you need to. I will tell you from experience that you should get your internal battery changed out if you havent done so already to keep from losing your settings and waypoints. The dealer will have to save them for you though and put them back on. Furuno made a GP7000 to replace this one and it's uses SDcards and is nothing like the rest of Furuno's product line. The best replacement for this unit is the Garmin GPSMAP 700 series. You can use your old furuno transducer if you have one (with an adapter plug). This garmin unit also has a built in GPS or you can use an external one. The 700 series will be shipped in April. Check out Garmin's website or mid-shore electronics.
How to program frequency 8113.5 on my Furuno FSS1503 Single Sideband Radio Telephone?
To program a specific frequency on the Furuno FSS1503 Single Sideband Radio Telephone, you can follow these steps:
- Press the Power button to turn on the radio.
- Press the Frequency button to select the desired frequency range (HF, MF, or VHF).
- Use the arrow keys to select the desired frequency (8113.5 kHz in this case).
- Press the Enter button to confirm the frequency selection.
If the frequency is not working, there may be other factors affecting the radio's performance, such as interference, atmospheric conditions, or a faulty antenna. It is recommended to use an antenna coupler or tuner to optimize the radio's performance and ensure proper transmission and reception. If you are still experiencing issues, you may need to consult a professional technician or the manufacturer's customer support for further assistance.
I need service manual book furuno fcv 620
The user manual is easy to find but they post warnings if you try to open it up and state you should contact an authorized repair facility or the factory. I could not find one.
