20 Most Recent
Broan-NuTone CV554 Cyclonic Bagless Central System Vacuum Questions & Answers
Breaker keeps tripping
If you can unplug the central vac and plug it into a different outlet that you know is on a different breaker and test it out to see if it trips the breaker,or temporarily rewire the central vac to a different power supply.Make sure the breaker is the correct amperage for the central vac,last read the instructions to see if you need a dedicated circuit breaker,you might have to many accessories plugged into that outlet.
I have a 4 yr old vx6000c central vac that constantly blows house breaker
This unit requires a 15AMP 120 VOLT dedicated circuit. If there are other appliances or items on this central vacuum circuit, this could overload the circuit causing it to pop. The other issue that could be occurring is that the central vacuum is on a GFI circuit or ARC fault circuit. Central Vacuum Units are not designed to run on these types of electrical circuits.
Please visit our website if you need a replacement part or if you have more questions. Or give us a call at 1-800-533-3249
Don't forget to like and visit our Facebook page.
https://www.facebook.com/QualityHomeSystems/
1996 Jeep Cherokee interior lights do not shut off
It's very likely that you left the interior switch in the on position. There are usually 3 positions the switch can be in "OFF, ON , and AUTO. The switch should be in "AUTO" so that the interior light will turn off when you close the door.
Tornado cv30
Sound like the beater bar is full of hair and other debris causingthe motor to be under too much of a load. Extract the beater barand clean it. The bearings at each end may also need tobe lubricated or replaced. The should turn real easy.
Tornado cv30 1
will shut down if the motor over heats check for blocked filters
