20 Most Recent
Humminbird Wide Side Trolling Motor Transducer Questions & Answers
Humminbird 215 max fish finder- Replaced batteries and now won't turn on, the batteries are good and connections are good.
Brand: DIVTEK New water bicycle - Pretty Fast. Sport Fun, Take a Deep Breath. Cool Inflatable Water Bike.Significant TIPS : Please check the FREE conveyance time prior to purchasing our water bicycles. After you consent to the transportation time, then, at that point you can submit a request. We don't acknowledge discounts on the way, Hope you can comprehend. much thanks Bike boat Up. Our Water Bikes Bike boat. A elite water bike - customary bike position. Lightweight, simple to utilize, flexibility and clean. Appropriate for: Aquatic Parks, Aqua Lakes, Rivers and ocean, and Good thought for Local Water Bikes Rental Business HIGH QUALITY: The water bicycle is made of 6061 aluminum combination outline with heating. The outside is compact and lovely. The pedal and seat both have a dependable quality. Elite: The heading control framework without paddling capacities is steady, solid and simple to keep up. The transmission framework made of a high-strength coordinated belt is both waterproof and rustproof. The buoys are physically produced using 1000D 0.9mm polyurethane covering. Your floor is furnished with light and safe scoring strips. follow the linkhttps://waterbaike.blogspot.com/2021/06/with-water-divtek-water-bikes.html
How to connect Humminbird fish finder to Motorguide trolling motor
I would use slip rings to tie existing cable to prop motor support shaft and mount transducer to motor housing. 'slip ring'--metal ring a little bigger than shaft with a nipple the size of the cable. OR call the bird at 1-800-633-1468 or www.humminbird.com/Category/Company/Contact-Us/ and use some southern/country slang when talking. Best of luck 'you all'.
My humminbird 898c is stuck on the loading screen, won't turn off or anything, any ideas?
First steps (you may have done done) check all wiring connections ,transducer, power,ext. at both ends. Attempt power up again. No change. Call 1-800-633-1468 with model & serial #'s. OR Disconnect all cable connections from unit and with a strip of aluminum foil short out all the connections on the 898c.(not the cable). Attempt power up again. If unit will let you go to 'System Status' screen & record. Hope your unit works.
