20 Most Recent
Humminbird Matrix 97 Combo Fish Finder And Gps Chartplotter Questions & Answers
I get an error msg
If you can find someone with a Humminbird that has the same pin configuration on the transducer cable, switch yours out and put the transducer in a bucket of water to see if it works. Otherwise, make sure the cable at the plotter end is firmly placed in the socket, and that no pins got bent in the past. Some of these models came with a metal clip that holds the end of the cable(s) tight to the plotter and is held tight by the mounting bracket screws.
I cannot get a clear
sounds like you might not be getting a full 12 volts DC to the unit. check the voltage with a volt meter,, and also check to make sure that your battery/batteries are in top shape and charging properly. ( one bad battery in a bank of many can cause voltage issues ).
c...
HAVE A HUMMINBIRD MATRIX-97 ,CARD
in 99% this problem arises because of firmware corruption.... or rest 1% hardware failure... so update firmware of your gadget ...
Hope this has helped you...
Thanks..
Humminbird 215 max fish finder- Replaced batteries and now won't turn on, the batteries are good and connections are good.
Brand: DIVTEK New water bicycle - Pretty Fast. Sport Fun, Take a Deep Breath. Cool Inflatable Water Bike.Significant TIPS : Please check the FREE conveyance time prior to purchasing our water bicycles. After you consent to the transportation time, then, at that point you can submit a request. We don't acknowledge discounts on the way, Hope you can comprehend. much thanks Bike boat Up. Our Water Bikes Bike boat. A elite water bike - customary bike position. Lightweight, simple to utilize, flexibility and clean. Appropriate for: Aquatic Parks, Aqua Lakes, Rivers and ocean, and Good thought for Local Water Bikes Rental Business HIGH QUALITY: The water bicycle is made of 6061 aluminum combination outline with heating. The outside is compact and lovely. The pedal and seat both have a dependable quality. Elite: The heading control framework without paddling capacities is steady, solid and simple to keep up. The transmission framework made of a high-strength coordinated belt is both waterproof and rustproof. The buoys are physically produced using 1000D 0.9mm polyurethane covering. Your floor is furnished with light and safe scoring strips. follow the linkhttps://waterbaike.blogspot.com/2021/06/with-water-divtek-water-bikes.html
