20 Most Recent
Raymarine Ray54 Vhf Marine Radio Dark Grey Questions & Answers
Where can I buy a
Sadly, the mic and cord for the Ray54 have been discontinued by the manufacturer. I guess if you plan to buy a Raymarine VHF, your best bet would be to buy a spare radio for parts. Unbelievable.
Here's the link to that conversation from Raymarine support.
I realize this question is old, but the information could be helpful to someone else.
-Steve
Raymarine 54 Mic Chord
The Raymarine ST8002 Smartpilot the unit powers up but does not work when the auto mode is selected. The hydraulic motor does not engage when a course is set. What could be the source of the fault?
According to a post on the Raymarine forum, this error message could indicate an issue with either the steering, the drive unit, the rudder reference unit (if fitted), or the course computer . The post suggests a few tests that you can do yourself to figure out which item is causing the issue.
I suggest that you try the following steps:
Check the connections between the ST8002 SmartPilot and the other components of your autopilot system.
Check the calibration of the ST8002 SmartPilot and the other components of your autopilot system.
Check the hydraulic fluid level and the hydraulic pump pressure.
Check the hydraulic pump motor and the hydraulic pump solenoid valve.
If none of these steps work, I recommend that you contact Raymarine customer support for further assistance.
11/20/2023 9:03:39 PM •
Raymarine...
Answered
on Nov 20, 2023
How do I connect my garmin 741sx with my raymarine St 4000 with nmea 183
To connect your Garmin 741sx with your Raymarine ST 4000 using NMEA 183, you will need an NMEA 0183 interface cable to connect the two devices. Here are the steps to follow:
- Obtain an NMEA 0183 interface cable that has the correct connectors for your Garmin 741sx and Raymarine ST 4000.
- Connect one end of the NMEA 0183 interface cable to the NMEA output of your Garmin 741sx.
- Connect the other end of the NMEA 0183 interface cable to the NMEA input of your Raymarine ST 4000.
- Configure your Garmin 741sx to output NMEA 0183 data. Refer to your Garmin 741sx manual for instructions on how to configure NMEA output.
- Configure your Raymarine ST 4000 to receive NMEA 0183 data. Refer to your Raymarine ST 4000 manual for instructions on how to configure NMEA input.
- Once both devices are configured, the data from the Garmin 741sx should be transmitted to the Raymarine ST 4000 via the NMEA 0183 interface cable.
2/23/2023 5:01:41 PM •
Raymarine...
Answered
on Feb 23, 2023
Raymarine c120 classic intermittent no data source
"Finally convinced him that **your** specs requiring the 4c cable at those lengths was correct"
You know we are Fixya and not Raymarine? We just have a Raymarine category for handy filing of questions and answers.
This question needs a factory service department technician on the phone.
As a boat owner, who doesn't have radar, and reading your post carefully, I would suggest the connection at the top of the mast. It is far more hostile up there, and it has been up there a long time.
7/10/2021 9:20:46 PM •
Raymarine...
Answered
on Jul 10, 2021
