20 Most Recent
Garmin 200/50khz, 10/40deg, Plastic, Transom Mount, Depth, Temp Questions & Answers
Using Nuvi 265WT in UK.Have
Hi
Try disabling the France map by going into Tools-> settings->Map. After this go to Map info and check the map to enable it or disable it, if it’s not working restart and try again. However, try to restore the map by selecting restore option.
If you are unable to resolve the issue then you'll need to reset your GPS device. Depending on the model of your Garmin 256 you can reset by pressing the reset button on the bottom of the unit. If you are unable to find the reset button then slide the power key to on/off position and hold it for 10 seconds.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
7/25/2010 11:58:58 AM •
Garmin...
Answered
on Jul 25, 2010
Sounder transducer?
I believe like my own Garmin I have a 178 which is the mono version, same transducer though, you alter the frequencey setting in your main reciever set up program.
9/26/2008 2:08:40 PM •
Garmin...
Answered
on Sep 26, 2008
