20 Most Recent
Uniden Qt206 Thru Hull, Digital Depth Gauge Questions & Answers
Accurate when still display changing inaccurate
You might have air bubbles trapped on surface of transducer. Use soap on it so water sticks to surface, no wax, oil, or grease.
If transducer is mounted inside the boat, you have air trapped between it.
The depth gauge beeper stay on and the depth runs
Check the battery power at the unit with a DC volt meter, and also use the meter's AC setting across the power post on unit. If AC volts are above a tenth of a volt, the wires to battery may be to small, not allowing enough current to drive the transducer and electronics in unit.
My display numbers are upside down.
If this unit has worked before, and suddenly looks upside down, you are most likely seeing a display with missing or defective sigments. There are 7 segments needed to make number from 0 to 9. When a segment goes bad, you will see something different.
Sometimes the internal connections to the LCD display are dirty or corroded.
Unit showing 88.8 in the LCD window.
Hello geld1. Your problem is the transducer, cable or connector. Check transducer with an ohm meter, flex the cable while ohming the restance shouldn't change. The location and mounting of the transducer could be the main problem. Use the the correct gel film including a secure postion support.
