20 Most Recent
Northstar Explorer 657 Gps/Chartplotter/Sounder Combo With Tm Transducer Questions & Answers
Northstar
Explorer 657
GPS/ Fishfinder
Screen
It appears that the back-light, a Cold Cathode Fluorescent Tube about 3mm diameter, is not working.
There are two likely causes.
1. Tube has failed.
2. High Voltage supply circuit has failed.
I'm currently pulling my unit apart to determine the cause. I suspect the tube is the problem but I will post more when I have it apart
Does anyone know what the correct operating voltage of this Cold Cathode Fluorescent Tube is? Northstar could not provide me with a service manual.
The screws are 1/16" or similar Allan Screws (about 1.6mm internal between flats). They usually can be undone with a 1/16 Allan Key but some of the screws can't be unscrewed with this key.
I'm having difficulties uploading the photos at the moment but I will try and fix that.
8/5/2022 11:17:58 AM •
Northstar...
Answered
on Aug 05, 2022
Black screen
If it is connected to the boat motor check the voltage that is coming from the engine and clean the battery post. This solved the screen flickering.
If you don't want to do that just call Northstar customer support and see what they suggest.
Phone (Toll-free) 1-800-628-4487 or (Direct) 603-324-2042
That will get you better support.
3/25/2016 12:16:07 AM •
Northstar...
Answered
on Mar 25, 2016
I Have a 657 northstar
I had the same problem with my 657 I found it was moisture inside the unit that was causing the low voltage alarm to go off pull it apart and let it dry out inside
9/9/2011 8:48:53 AM •
Northstar...
Answered
on Sep 09, 2011
My screen keps on flickering
Is it connected to your boat motor if yes check your voltage from your engine and clean your baterry post, sometime you get what they call electrical sound that will disrupt a clean electrical wave for your system.
11/29/2009 2:36:15 PM •
Northstar...
Answered
on Nov 29, 2009
