20 Most Recent
Eagle Fishelite 642c Color Fishfinder Gps With Internal Antenna Questions & Answers
Eagle 462c will not power up
I called Lowrance and since Eagle has been discontinued, they no longer service them. However, they will offer to upgrade to Lowrance. I ended up getting a HDS-5 for $480.00. Not a bad deal since my Eagle was toast.
I hit menu and it
Reboot procedure from from Eagle tech support:
1. Turn unit off
2. Press and hold pages key
3. Press and hold power key at same time
4. Unit will power up. Wen map appears, release both keys.
5. Press exit 3 times
6. Press the menu key twice and it should now access the main menu
No backing light
Eagle only gives out a 1 year warranty on their products, so as far as I know you wont be able to get it fixed for free, but I would email them and see what they say.
Page button does not work.
Same problem, I found out how though. If your willing to lose your waypoints like I was, turn the unit on, then off. Hold the Zin and Zout buttons down and and then hold the power button down, when you get to the map, release Simultaneously and it will reset and work. and questions email me at
[email protected]. Hope this helped.
Where would I send an Eagle Fish Mark 640 for repairs?
I am a bit reluctant to answer this question as it may sound like I am being rude, but here goes. Type the name into google. It will tell you this is a discontinued product, and will also tell you the nearest service place to contact which will probably be a Lowrance agent. Call them and ask if it can be repaired. If so send it to them with a note explaining what the problem is. If it cannot, throw it in the bin and buy a new one. Easy.
Can I wire it together?
The impedance match most likely won't. I advice you not to attempt. Replace with matching Eagle model transducer.
