20 Most Recent
JRC Jma-2343 4kw Crt Radar Questions & Answers
JRC Radar Scanner when rotating
There is a seal on the antenna scanner shaft, just below the seal there are two bearings, thou the antenna are enclossed moisture still get inside and get to these bearings. Try and get a small amount of wd40 on the bearings, if not, you will soon begin to see false echoes on the screen because the motor on the scanner or antenna will begin to work harder causing a drag causing these echoes. Good luck.
Im using a 3728 radar open array..the scanning
You will need to adjust the timing on the radar antenna which is in the setup menu. You will need to refer to the installation instructions on exactly how to access the installation menu. There should be a small circle in the center of the screen, but not like you are mentioning.
