20 Most Recent DCS WO-130 Stainless Steel Electric Single Oven Questions & Answers
Oven beeps and display shows F7
Error F7 means that the keypad is shorted or stuck and to resolve this issue you'll have to replace the Electronic Range control (ERC).
The code can be caused by a faulty keypad or a stuck keypad which may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
a.- Pushing CLEAR/OFF pad.
b.- Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if code come on again, the problem is in the Control. Replace control to solve it. If code does not come on, problem is with the Key Panel
Hope helps.
7/8/2018 6:12:26 PM • DCS WO-130... • Answered on Jul 08, 2018
2answers
DCS Single Wall Oven Model WO-130-SS
Order part #211708 from 1-888-281-5698 DCS Fisher@Paykel new Zealand. Only need philips head screw driver and twenty minutes. This part is a upgrade for lcd only. old part was a three part system, but no need for three parts only lcd screen.
7/26/2017 7:24:45 PM • DCS WO-130... • Answered on Jul 26, 2017
0answers
4answers
DCS elect wall oven LCD display
Had the same display issue with my DCS WOS-230. The display was fading and made it very hard to read clock and temp setting. Called DCS/Fisher Paykal and was told I need the Control system kit for $335.00 to fix the issue. After reading the input on this issue on this site I pushed them to sell me just the DCS EOC 211696 double display module 100-01095-00. Install took 10 minutes and everything works great. Thanks all for laying the groundwork as DCS will really push hard to sell you the more expensive kit that you do not need.
3/12/2015 5:23:41 PM • DCS WO-130... • Answered on Mar 12, 2015
0answers
DCS WOS-130 oven won't turn off. I've turned the breaker off and back on but each time the oven starts heating without turning it on through the controls.
This sounds like a stuck relay on the control board or in rare cases a short to ground in the oven element itself. Test the oven element terminals to the case. If there is continuity then replace the element. If it checks Ok then more than likely there is a welded relay on the board. you can try tapping the relays on the board. Sometimes this jars the contacts loose and things work again. Be prepared to replace the control if this is the case.
3/2/2014 5:43:08 PM • DCS WO-130... • Answered on Mar 02, 2014
2answers
Display on our dcs oven is beginning to fade. can i fix it?
Hello just repaired my DCS wall oven. LCD screen is no good. part # lcd only is 211708. cost is $85.00 dollars with shipping. Took me twenty minutes to install. just need one philips head screw driver.Just call DCS Fisher@Paykel 1-888-281-5698 new Zealand.
4/20/2011 10:42:58 PM • DCS WO-130... • Answered on Apr 20, 2011
0answers
While cleaning oven the door hs remmained locked
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
10/13/2010 9:27:15 PM • DCS WO-130... • Answered on Oct 13, 2010
The display - clock and the oven temp. readout on
the display or readout need to replace
10/3/2010 3:19:57 AM • DCS WO-130... • Answered on Oct 03, 2010
Dcs wos-130 wall oven\r\nclock display dim and
Hi
Thanks for using FixYa. It seems that control panel needs to be replaced as even the function keys are not working and the clock display is also dim. If you get this done by a professional the cost should be around $200-$300 depending on the cost of the control panel. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
5/22/2010 3:21:16 PM • DCS WO-130... • Answered on May 22, 2010
DCS over F7 error beeping
KEYPAD BUTTONS ARE REMAINING CLOSED FOR MORE THAN 32 SECONDS. REPLACE KEY PAD,DUE TO STERCHED PANEL MEMBRANE
2/17/2010 11:11:45 PM • DCS WO-130... • Answered on Feb 17, 2010
F2 and beeping sound...what gives?
open the cpu and din remove the memory and use the hair brush into the memory housing also applying hair brush into your memory and din put again into original position, and try to on it
7/4/2009 8:42:47 PM • DCS WO-130... • Answered on Jul 04, 2009
DCS WO-130 Stainless Steel Electric Single Oven Logo
27 questions posted
Top DCS Ovens Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a DCS Oven Expert? Answer questions, earn points and help others
View Most Popular
DCS Ovens
  • DCS Ovens
Most Popular Question
dcs elect wall oven lcd display
  • Ovens
