20 Most Recent Eclipse EA3422 Car Audio Amplifier Questions & Answers
How to wire for 3 ch mode
this is the manual and you will find all you need in it.
http://www.fixya.com/support/p78783-eclipse_ea3422_car_audio_amplifier/manual-18248#
11/2/2019 4:18:47 AM • Eclipse EA3422... • Answered on Nov 02, 2019
Need help in installing amp.
depending on the power consumption of the amp u will need to run a 4-12 ga wire to the positive battery terminal. then u need to ground it with a wire connected to a clean ground like a chassis bolt. next u need preamp outputs on ur deck to send audio signals to the amp. lastly u need to hook up a remote wire to the blue wire in ur cd player harness
12/5/2013 3:44:00 AM • Eclipse EA3422... • Answered on Dec 05, 2013
2answers
What is the wattage output on this amplifier
If it doesn't say call the mafactor
12/3/2013 2:23:17 AM • Eclipse EA3422... • Answered on Dec 03, 2013
2answers
What is the max wattage for this amplifier
Whatever the watts is on amp
11/15/2013 5:22:53 AM • Eclipse EA3422... • Answered on Nov 15, 2013
0answers
0answers
0answers
User Maual?
Be the first to answer 6/15/2012 11:46:49 AM • Eclipse EA3422... • Posted on Jun 15, 2012Be the first to answer
0answers
0answers
I have a 4 channel amp that id like to know how to
to bridge it you would connect one wire to the positive from one of the two terminals and one to the neg from the OPPOSITE terminal
5/15/2011 4:07:30 AM • Eclipse EA3422... • Answered on May 15, 2011
How do i set the amp for one 8 ohm sub speaker
If you meant to connect your Sub woofer speaker which has an impedance of 8 ohms , you can use the bridge connection between the two channels to connect.
This will be noted on the output terminals and so the speaker can be bridged between the left and right channels.
1/12/2011 6:34:56 AM • Eclipse EA3422... • Answered on Jan 12, 2011
Wont turn on i bought
well this is what you do to check it to see if you bought a blown amp.
wire it into your car and then take a digital volt meter check to see if you have power and ground and remote turn on .
take the red lead and put it on the battery wire at amp and the black lead to the ground then see if you get 12volt to 14.4 use the amps ground for the black test lead if nothing you may have blown fuse or bad ground.
check the remote wire same way as about if you get 12 to 14.4 volt it works if not could be blown from radio or bad ground
checking the ground put the black meter lead on ground wire and the red lead on 12 volt power source if nothing a bad ground.
if your get voltage on the remote wire and battery wire and have good ground then you need to call the seller and get your money back ..
10/16/2010 5:04:37 PM • Eclipse EA3422... • Answered on Oct 16, 2010
EA3422 Car Audio Amplifier: Keep popping fuses...
Check your ground and power wire connections. It will most likely be a bad ground, if grounded in the trunk, get a longer wire of equal or greater thickness and ground to either chassis or battery. Also if you have the amp at full gain try dropping it a little back if getting a better ground doesnt help
6/7/2010 9:50:16 AM • Eclipse EA3422... • Answered on Jun 07, 2010
2answers
Car Ampli Problem
forget hooking this on a subwoofer. this amp produces only 50 watts per channel at 4ohms or 70 watts per channel at 2 ohms RMS...
If you try bridging the sub, it will only give out maybe 100watts bridged.
So..... if your sub is, lets say 1000watts RMS, youre just going to bust your amplifier to smoke...
Find a more decent and powerful amp. This amp is only intended for separates and lowend subs with an RMS of 80 to 150 watts
9/29/2009 4:48:28 PM • Eclipse EA3422... • Answered on Sep 29, 2009
Sony xplod XM ZR602
What ohm is your sub running at. Sounds like your runnig your amp to low an impedance causing it to thermally shut down, when it cools a bit it turns back on. Either that or you have wires crossed somewhere. Check your wiring and make sure the load of the speaker does not fall below the rcommended ohm of the amp. Usually 4ohms mono and 2ohms stereo
9/7/2009 1:40:50 PM • Eclipse EA3422... • Answered on Sep 07, 2009
Eclipse EA3422 Car Audio Amplifier Logo
34 questions posted
Top Eclipse Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Eclipse Car Audio & Video
Most Popular Question
need help in installing amp
  • Car Audio & Video
