20 Most Recent
Daikin FTXS12LVJU/RXS12LVJU 12000 BTU Class 23 SEER Mini Split-Heat Questions & Answers
WhAT DOES "iNTELLIGENT EYE" do?
The way I understand it, the 'eye' is just an infra red sensor that detects when someone is in the room. If it doesn't detect anyone, it reduces its power usage until someone walks back in and adjusts accordingly.
12/12/2015 11:44:43 AM •
Daikin...
Answered
on Dec 12, 2015
Mini split drain trouble
There is a temp. probe on the inside unit.(evaporator). If you open the front panel you should see 2 white air filters. With the right side one removed you should see a black probe on the coil. Possibly that probe needs replacement. Very possible there is also a defrost sensor connected to the outside condensing unit. That sensor is connected via a white plug in connector.. Replace that one too if possible.
3/2/2014 2:16:20 PM •
Daikin...
Answered
on Mar 02, 2014
Daikin fhyc140kve8
Outdoor unit will auto switch off when preset temp is reached, then switch on again auto as temp varies
Heat stops constantly
try changing pipesensor or thermostat they are most likley to go on a aircon let me know if it worked it should cause i had the same problem with mine till i changed the pipesensor and thermostat
Hello
How can I disassemble my
Why do you need to dismantle this? Some of these types of cooler do not have replaceable parts inside. They are usually classed as a "Throw away" machine. It is often easier and cheaper to replace it than repair it.
4/9/2024 1:31:04 PM •
Heating &...
Answered
on Apr 09, 2024
Homebasix Olliscating parabolic heater how to reset
o reset your Homebasix Oscillating Parabolic Heater, follow these steps:
Unplug the heater from the power source.
Locate the Manual Reset Button on the heater. It's usually a small button or switch.
Use a fireproof, non-conductive rod (such as a wooden stick or plastic tool) to press the Manual Reset Button.
After resetting, plug the heater back in and check if it functions properly.
Remember to ensure that there are no flammable objects within 3 feet of the heater and that it is placed on a stable surface.
4/7/2024 11:23:24 AM •
Heating &...
Answered
on Apr 07, 2024
