20 Most Recent
Goodman Manufacturing Hvac Direct R410A Packaged HP 13 SEER 2 Ton 24K Questions & Answers
Where is the low voltage fuse located on a GPH1442H41AA
its not a car or a truck moved you to HVAC
home heaters can not be driven.
all there systems have a service manual
mine was free, I asked them and wow free.
so get it and read.
even keep it, for next time
caps and contactors all love to fail on all major HVAC
GPH1442H41 Goodman 3.5 Ton Pkgd 14 Seer Hp R-410a Horizontal 14 Seer 3.5 Ton
the fuses are NOT just one fuse
and all mine are 240ac and also 120vac
even the thermostats have 24vac transformer that is 120v 20amp breaker.
mine has fuses for the compressor in the 200amp load center
and not any inside out door, compressor,/condenser.
there is no fuse, all are on breakers this is no 1950 year AC
why not post whats wrong.
screens on thermostats blank its backup battery dead.
check all breakers
check AC contactor for dead in compressor pad boxl
check AC capacitors
check both blower capacitors.
check for door interlock switches tripped
tell what is dead, AC or heat.
no clues at all, just false hunts for fuses no longer used on AC or heaters. they use breakers for 60 years.+
i guess is a heat pump and guess both modes dead.
all in one not split
get manuals from them
ask
https://www.goodmanmfg.com/products/packaged-units/heat-pumps/14-seer-gph14h
1/16/2023 1:15:20 PM •
Goodman...
Answered
on Jan 16, 2023
Hello
How can I disassemble my
Why do you need to dismantle this? Some of these types of cooler do not have replaceable parts inside. They are usually classed as a "Throw away" machine. It is often easier and cheaper to replace it than repair it.
4/9/2024 1:31:04 PM •
Heating &...
Answered
on Apr 09, 2024
Homebasix Olliscating parabolic heater how to reset
o reset your Homebasix Oscillating Parabolic Heater, follow these steps:
Unplug the heater from the power source.
Locate the Manual Reset Button on the heater. It's usually a small button or switch.
Use a fireproof, non-conductive rod (such as a wooden stick or plastic tool) to press the Manual Reset Button.
After resetting, plug the heater back in and check if it functions properly.
Remember to ensure that there are no flammable objects within 3 feet of the heater and that it is placed on a stable surface.
4/7/2024 11:23:24 AM •
Heating &...
Answered
on Apr 07, 2024
