20 Most Recent DCS RGS-305 Professional Gas Kitchen Range Questions & Answers
THE OVEN DOOR POPPED OUT ON THE BOTTOM (HINGE).
Hello, welcome to FixYa.
I understand by your post you have a DCS RGS-305 in which the hinge "popped" out, correct ?
I'll address the removal/replacment of the oven door first. These doors are only meant to be taken off with the hinge "locked", as shown here.
1) Fully open the oven door and locate hinge lock lever. After locating the hinge lock lever, pull it to the lock position as shown.
example:
Pull the oven door up at roughly 45°, and pull the oven door out of its hinge receptacles and away from the unit.
That should address the oven door question. These are meant to come off in a certain manner as I mentioned so if the hinges are not "locked" when the door was pulled off, they will need to be locked before going back on.
Let me know if you have any trouble at that point and for sure I'll assist you. Good luck. If this indeed solves your plroblem please take a moment to rate the assistance here.
If it does not, please let me know and we can go from wherever you're stuck.
Regards,
Macmarkus :)
10/28/2018 4:24:25 PM • DCS RGS-305... • Answered on Oct 28, 2018
0answers
Infrared burner dont work
www.searspartsdirect.com/.../dcs...cooking.../range...RGS305
7/6/2017 2:00:45 PM • DCS RGS-305... • Answered on Jul 06, 2017
0answers
Oven temperature is 25-50F too low depending on
Time to replace the thermostat!
11/9/2015 10:54:46 PM • DCS RGS-305... • Answered on Nov 09, 2015
2answers
Igniter switch on top burner will not shut off
try thoroughly cleaning the burners, particularly the holes in the ring that the gas come through. The gas come through to heat the ignitor so that the ignitor knows to stop trying to light the burner ; if the holes are clogged the ignitor doesn't heat. The burner is easily disassembled from the top by removing a thin bolt, and you can clear the holes with a paper clip.
4/23/2015 8:07:51 PM • DCS RGS-305... • Answered on Apr 23, 2015
0answers
0answers
Service manual
Be the first to answer 1/17/2014 3:05:41 AM • DCS RGS-305... • Posted on Jan 17, 2014Be the first to answer
Dcs oven door unhinged
easy to install the door,before to remove check it how exactly the position of the door its a clip typr,or get the manual to see the procedure,open the door,pull open then if u see the hinge we have small lock in the hinge u psh it up the lock then slowly close the door,be care bcoz the hinge is powerfull,if u close the door see the hinge how to remove the door.
tnx gerbee
11/7/2013 8:55:03 PM • DCS RGS-305... • Answered on Nov 07, 2013
0answers
DCS commercial range #36-6-1L running
You might need a new thermocouple. The thermocouple tells the oven that the pilot is lit and that it is ok to let gas into the oven. It is the metal rod that is connected to the pilot. They are fairly cheap and easy to install.
7/8/2013 6:20:00 PM • DCS RGS-305... • Answered on Jul 08, 2013
The Infra-red broiler covered by glass does not sear or brown sufficiently
You might try covering the glass areas ( such as the door ) with tin foil... Hope that helps...
9/30/2012 5:33:41 PM • DCS RGS-305... • Answered on Sep 30, 2012
3answers
Ignitor stay on all the time after one burner is on
The simmer flame turns the ignitor off. On my range, the tube that supplies gas to the simmer flame was plugged with rubber-cement-like stuff. Cleaned it out with goof-off and a pastic-covered wire, and it works perfectly now.
9/15/2012 11:00:58 PM • DCS RGS-305... • Answered on Sep 15, 2012
2answers
Electric igniter does not stop sparking after the
On my DSC RGT-305 range it wasn't either the spark module or the wiring, it was one of the little rotary switches that sit behind the burner control knobs. It shorted out (verified with an ohm meter). The switch is made by State Tool & Mfg. Co. and the part number is 25300. Wayne
8/14/2012 5:48:08 AM • DCS RGS-305... • Answered on Aug 14, 2012
Convection
Hi there:You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time. Hopefully one of other experts will be able to provide you with a real solution. Thank you for using FixYa.
2/8/2012 1:21:56 PM • DCS RGS-305... • Answered on Feb 08, 2012
Convection fan
Hi Mike:You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time. Hopefully one of other experts will be able to provide you with a real solution. Thank you for using FixYa.
2/8/2012 1:21:48 PM • DCS RGS-305... • Answered on Feb 08, 2012
DCS RGS-305 Professional Gas Kitchen Range Logo
72 questions posted
Top DCS Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Paul Carew
vince
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
DCS Kitchen Ranges
  • DCS Kitchen Ranges
Most Popular Question
oven door popped out bottom hinge
  • Kitchen Ranges
