20 Most Recent
Rheem 13PJL36A01/RHSLHM3617JA 3 Ton 13 SEER R410a Heat Pump Questions & Answers
Why is my air conditioner freezing?
Either lack of refrigerant, stopped up metering device or capillary tube/s, or lack of air flow (due to bad blower motor, or dirty indoor coil)
12/13/2014 10:38:03 PM •
Rheem...
Answered
on Dec 13, 2014
WATHER LEAK
Trie to blow out your dran it might be blocked
8/21/2012 8:29:10 PM •
Rheem...
Answered
on Aug 21, 2012
Reem air unit have to hold down reset button to keep running
that reset is for the high pressure switch. this means your compressor is getting to hot which is then increasing the pressure and tripping the switch because the fan isn't running. usually if a capacitor is bad you can give the motor a "kick start " and the blade will then start turning. use a long stick or screwdriver to spin the blade but then you will know you need a cap. that switch is protecting your compressor, don't hold it down to keep it running. If you need further help, reach me via phone at
https://www.6ya.com/expert/thomas_092728000e6acb79
