20 Most Recent
Honda 2004 Odyssey EX Questions & Answers
96 accord ex 4cyl wont start battery new
bang, on the starter with a hamer all around the casing,the brushes wear out and no longer make contact with the comutator will useually make them move as they are sping loaded, this is a temp fix and only good 4 a cple of weeks! u can change the starter 4 abt $100 bucks or pay $150+ 2 have it done! and ur gonna get a referb bad piece with a $50 buck core charge!!!rip off. what i do is buy the brushes from th auto pts store and replace them ur self abt 6 bucks abt 1 hrs work!let me know if it worked 4 u!
Hello
How can I disassemble my
Why do you need to dismantle this? Some of these types of cooler do not have replaceable parts inside. They are usually classed as a "Throw away" machine. It is often easier and cheaper to replace it than repair it.
4/9/2024 1:31:04 PM •
Heating &...
Answered
on Apr 09, 2024
Homebasix Olliscating parabolic heater how to reset
o reset your Homebasix Oscillating Parabolic Heater, follow these steps:
Unplug the heater from the power source.
Locate the Manual Reset Button on the heater. It's usually a small button or switch.
Use a fireproof, non-conductive rod (such as a wooden stick or plastic tool) to press the Manual Reset Button.
After resetting, plug the heater back in and check if it functions properly.
Remember to ensure that there are no flammable objects within 3 feet of the heater and that it is placed on a stable surface.
4/7/2024 11:23:24 AM •
Heating &...
Answered
on Apr 07, 2024
Can this unit be installed thru a wall with the sleeve/ box that comes with it? CW-XCI20AU
Obviously window and wall a/c units are not tradable, in spite of the fact that I don't have the subtleties of the distinction.
Alter Window units are intended to exploit the way that a window is a flimsy segment; vents outwardly of the a/c case can be near within part of the a/c unit, yet be outside (where they must be). This might permit the window units to be less expensive. Interestingly, a wall can be 6" thick or more; wall units should have all vents near the rear of the unit. BTW I generally felt that the vents in the side of a window unit were for admission of air at encompassing temperature to then be coordinated through the condenser curl at the back plane of the unit to be depleted out the back (presently more sweltering than surrounding), however as a matter of fact a portion of the side vent region may likewise be utilized for ousting air which cools engines. It may be the case that in a window unit the venting on one side is committed to admission of air for the condenser loop and the venting on the opposite side is for exhaust. This would forestall the hot exhaust air being pulled in the admission for the condenser cooling air.
Window ACs versus Through-the-Wall ACs
It's not difficult to think about window and through wall ACs, since they're comparative in cooling limit and size, yet through-the-wall units will generally be somewhat more productive in light of the fact that they make an impermeable seal in the room.
The significant contrasts between these ACs include establishment and venting. Window ACs fit through a window and don't need long-lasting establishment, while through wall ACs are really incorporated into the wall - making them well known in rooms without windows or for individuals who like to let their windows be.
Wall forced air systems normally just vent warm air through the rear of the unit, while window ACs vent from the sides and back. Hence, window and through wall models are not exchangeable (regardless of whether they're a similar size). Generally speaking, in the event that a window unit vents out its side, the wall will obstruct the vents and cause overheating. Select window AC models can be introduced through a wall, however provided that they have a slide-out case wall sleeve. Peruse more on wall sleeves.
3/25/2024 3:48:35 AM •
Heating &...
Answered
on Mar 25, 2024
