There are 2 fans on your motor , air con fan comes on when the air con is switched on. The engine coolant fan comes on when the motor reaches operational temp, around 85 to 95 degrees . there is a heat censer on the engine block or radiator that controls battery voltage to the fan. with a volt meter check both sides of this censer for battery voltage, with the engine hot. replace if faulty.
? 1:13
https://www.youtube.com/watch?v=bgIQ9AD82zU
Feb 14, 2013 - Uploaded by Blog Ternet
... how I permanently disabled the car alarm on my 2001 HondaCivic 2 door coupe. ... My alarm remote broke and im not able tostart it now ... 2005 ford ranger ... up or remote start you will completely disable your car/truck until you go ... I have'nt started my car since January. the alarm is on & it won't shut ...
Dec 6, 2009 - Hi I have a honda 2002 Civic EX with a factory alarm. ... From a 2001-2005 Civic alarm manual, the situation you describe, where the dome ... FYI, to putyour car in valet mode, you do the same proceedure, all within 3 seconds. .... Remote part works, but the car won't start (green key light), PinkCupcakes ...
Did you check the pressure switch, I would assume that it would be a NC switch, you may have a overcharge or air in system. Are you sure the pressure switch is good ? Don't ground the switch try using a jumper.
bang, on the starter with a hamer all around the casing,the brushes wear out and no longer make contact with the comutator will useually make them move as they are sping loaded, this is a temp fix and only good 4 a cple of weeks! u can change the starter 4 abt $100 bucks or pay $150+ 2 have it done! and ur gonna get a referb bad piece with a $50 buck core charge!!!rip off. what i do is buy the brushes from th auto pts store and replace them ur self abt 6 bucks abt 1 hrs work!let me know if it worked 4 u!
Question edited for clarity, full 'make model (what it is)'.
Email address removed. You don't need the site's 12 million annual viewers emailing you to say they can fix it for a thousand bucks!
Finally, Please don't type in all CAPS, it is considered SHOUTING and is harder to read.
Repair Clinic has some good ideas, but your model is discontinued
Here are the steps you might want to follow:
Setting the Draining Cycle Times (Dump Interval): This setting controls how often the unit dumps the water. You can adjust this setting to reduce the frequency of water dumping.
Setting the Drain off Delay Time (Dump Delay): This setting controls the delay time before the unit starts to dump the water after it has been turned off.
If adjusting these settings doesn't work, there could be other issues with your unit. For example, a continuous water dumping problem could be due to a faulty dump valve or a problem with the float valve.
Why do you need to dismantle this? Some of these types of cooler do not have replaceable parts inside. They are usually classed as a "Throw away" machine. It is often easier and cheaper to replace it than repair it.
o reset your Homebasix Oscillating Parabolic Heater, follow these steps:
Unplug the heater from the power source.
Locate the Manual Reset Button on the heater. It's usually a small button or switch.
Use a fireproof, non-conductive rod (such as a wooden stick or plastic tool) to press the Manual Reset Button.
After resetting, plug the heater back in and check if it functions properly.
Remember to ensure that there are no flammable objects within 3 feet of the heater and that it is placed on a stable surface.
