Question edited for clarity, full 'make model (what it is)'.
Email address removed. You don't need the site's 12 million annual viewers emailing you to say they can fix it for a thousand bucks!
Finally, Please don't type in all CAPS, it is considered SHOUTING and is harder to read.
Repair Clinic has some good ideas, but your model is discontinued
Here are the steps you might want to follow:
Setting the Draining Cycle Times (Dump Interval): This setting controls how often the unit dumps the water. You can adjust this setting to reduce the frequency of water dumping.
Setting the Drain off Delay Time (Dump Delay): This setting controls the delay time before the unit starts to dump the water after it has been turned off.
If adjusting these settings doesn't work, there could be other issues with your unit. For example, a continuous water dumping problem could be due to a faulty dump valve or a problem with the float valve.
