20 Most Recent Jaguar 1996 XJ6 Base Questions & Answers
96 xj6 changed ecm fuel pump fuel filter positioing sensor and battery car is dead wont crank
Have you checked the starter motor ? Is there a good bond between the body and chassis metal parts? Determine if a fuse for the starter relay has blown.
11/9/2016 10:35:23 PM • Jaguar 1996 XJ6... • Answered on Nov 09, 2016
My X Type 2L Turbo Diesel is making a loud noise, Jaguar tell me I must replace the Aircon compressor. Is there anyway around this instead of spending on a new one.
Dealerships are normally robbing lying b*****ds. You should get 2-3 quotes from around the place, trying to find a mechanic somewhat familar with Jags .
7/27/2016 8:34:35 AM • Jaguar Heating &... • Answered on Jul 27, 2016
2answers
I have a Jaguar 99 XJ8 3.2. I got the undercar high pressure washed and put fuel in it. As soon as i drove off i noticed a resticted performance warning on the dash. It drove really slow and then ev
when you pressure was a car meaning engine or under you have to wait till is fully dry you may have short circuit your ecm or ignition depending where is located or is the alternator due to the water .
2/25/2014 2:26:24 AM • Jaguar Heating &... • Answered on Feb 25, 2014
My dirt devil jaguar deluxe carpet shampooer is
A fuse is designed to fail if a short or high amp draw condition occurs, a fuse can not cause a secondary safety(breaker) to trip.The unit has developed a short and must be replaced.
10/10/2013 10:50:49 AM • Jaguar Heating &... • Answered on Oct 10, 2013
Replaced compressor (used) pulled 30"
what are the gauge readings?
6/12/2011 5:17:08 AM • Jaguar Heating &... • Answered on Jun 12, 2011
Where to find charging point
what year is the jag.
4/29/2011 12:16:48 PM • Jaguar Heating &... • Answered on Apr 29, 2011
Hi my jaguar x type
Just two things without equipment. (That I know of). Is the clutch pulled in and the compressor running? If so, is the larger line coming from it cold? DON'T touch the small one! It could be very hot. If the clutch is not engaged, follow the larger tube from the compressor toward the fire wall. There is a low pressure safety switch that could be bad and can easily be by passed to check. Unplug the two wire connector and jumper those two wires. Be sure the AC control is set to "MAX COOL" and your thermostat is as low as it will go. Let me know if the clutch is engaged or the compressor running. You could have a 12 volt compressor with no clutch. They are out there. Roger
4/10/2011 7:27:22 PM • Jaguar Heating &... • Answered on Apr 10, 2011
I have Jaguar S-Type 2000,
If it is low on Refrigerant, it will cycle the clutch off. When the pressure rises from the lines equalizing, it will come back on. When it does stay running, does the larger line get cold? If not, it is probably low on refrigerant. Roger
4/7/2011 11:12:53 PM • Jaguar Heating &... • Answered on Apr 07, 2011
2answers
My car ac is not
Hi, There is air trapped on refrigerant line. Please release it and add refrigerant and retry.Check also recommended refrigerant for your air conditioning system. Regards, Jay
3/23/2011 3:41:21 PM • Jaguar Heating &... • Answered on Mar 23, 2011
I have a 2002 xj8
If it only happens when the ac is on maybe it doesn't have as much power as before? Bad batt or possibly a bad alternator. Also check for a good seal on the intake for the air.Also check the IAC valve on throttle body.Also check if fuel injectors are cracked or got clogged.If yes? Clean the injectors and check.Also it sounds like a coil pack is on the verge of dying. The a/c is putting more load on ignition and it can't keep up.And this is causing the problem. --------- But if all checked ok then it can be anything from a recharge (which indicates a leak) to from compressor.Or its weak compressor.-------------- Get this possibilities checked.This will point towards the faulty part causing this issue.-------This should help.Thanks.Helpmech.
3/7/2011 7:38:06 AM • Jaguar Heating &... • Answered on Mar 07, 2011
Airconditioner went out......the fan inside
CHECK THE CAPACITOR MAKE SURE THEIRS POWER GETTING TO THE FAN IF BOTH ARE GOOD REPLACE MOTOR
9/15/2010 3:46:08 AM • Jaguar Heating &... • Answered on Sep 15, 2010
Needs freon and I can't find the blue hose to put
Most air conditioners require a calibrated heated charging cylinder to add a charge, which should only be done by someone who is certified to do it, and has the proper equipment. Sorry, but this is NOT a do it yourself job.
4/1/2010 6:53:32 PM • Jaguar Heating &... • Answered on Apr 01, 2010
Needs a evaporator. Is this under the dash
Yes, it is against the firewall under the dash. It is probably the single hardest part of the a/c unit to replace.
10/14/2009 12:40:36 AM • Jaguar Heating &... • Answered on Oct 14, 2009
Car steams up and wont clear?
no that should not be refrigerant doing that. sounds like condensation. is the air on when this happens? you may have a clogged indoor air filter (on newer cars), which would overcool the air to a "wet" cold and could cause that fog/steam
10/9/2009 3:21:43 PM • Jaguar Heating &... • Answered on Oct 09, 2009
Cools for aprox 30 min. switches to heat. 86 xj6
check the thermostat
9/3/2009 10:41:07 PM • Jaguar Heating &... • Answered on Sep 03, 2009
WE HAVE A FEDDERS AZ7A09W2A Through the Wall Room Air Conditioner. IT WILL NOT TURN OFF. PULLING THE POWER CORD IS THE ONLY WAY. DOES ANYONE KNOW THE CAUSE AND OR REPLACEMENT PART?
Question edited for clarity, full 'make model (what it is)'. Email address removed. You don't need the site's 12 million annual viewers emailing you to say they can fix it for a thousand bucks! Finally, Please don't type in all CAPS, it is considered SHOUTING and is harder to read. Repair Clinic has some good ideas, but your model is discontinued
Fedders Air conditioner won't turn off
Repair Clinic https://www.repairclinic.com > RepairHelp > Fedders-Ai... Here are the most common reasons your Fedders AC compressor won't turn off - and the parts & instructions to fix the problem yourself.
Why Your Air Conditioner Isn't Shutting Off, and How to Fix It
Williams Comfort Air https://williamscomfortair.com > ac-wont-shut-off When your air conditioner won't shut off, it's natural to worry about wasting electrical power as temperatures become too cool for comfort. ..
4/24/2024 1:44:56 AM • Heating &... • Answered Yesterday
Jaguar 1996 XJ6 Base Logo
5 questions posted
Top Jaguar Heating & Cooling Experts
NOEL
NOEL
xxxxxx xxx
 Mikey
Mikey
Are you a Jaguar Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Jaguar Heating & Cooling
Most Popular Question
difference in transmission control
  • Heating & Cooling
