20 Most Recent Hitachi 9000 BTU Split A/C Questions & Answers
Hitachi ahu ac error code showing communication error between idu odu
Let's troubleshoot this problem:
  1. Check Wiring Connections:
    • Ensure that all wires connecting the IDU and ODU are securely connected. Loose or disconnected wires can cause communication errors.
  2. Inspect Terminals:
    • Examine the terminals for any signs of damage or corrosion. Clean them if necessary.
  3. Verify Correct Wiring:
    • Confirm that the wiring is correctly installed according to the manufacturer's specifications. Incorrect wiring can lead to communication problems.
  4. Fuse Check:
    • Check if any fuses related to the AC system have tripped or blown. Replace them if needed.
  5. Power Status:
    • Make sure the power supply to the outdoor unit is ON. If it's OFF, the communication cannot occur.
    86 Hitachi Air Conditioner Error Codes + troubleshooting - Arlington Air Conditioning Services (arlingtonairconditioningheating.com)
3/10/2024 9:08:38 PM • Hitachi Heating... • Answered on Mar 10, 2024
Where can l get filters for an Hitachi heat pump Model : RAS-52 CNHA
Many suppliers are available. Here is just one; https://www.orionairsales.co.uk/hitachi-air-conditioning-filter-spare-parts-829-c.asp
1/4/2024 6:18:41 PM • Hitachi Heating... • Answered on Jan 04, 2024
Hitachi split air #RAS-25CHA
Normally these systems need to be shut down for at least 2 hours and overnight is better. After you restore power at the breaker wait at least 10 minutes for the self test procedure to finish. Then make sure you are set to A/C chilled air as it defaults at every disconnect. Happy Thanksgiving.
11/24/2023 5:57:26 AM • Hitachi Heating... • Answered on Nov 24, 2023
2answers
Hitachi 11 ton ductable 07 error code
Hi, there might be an error in your refrigerant levels or temperature that needs to be corrected. If you add more refrigerant gas, then this should remove the error. Thank you.
11/2/2022 11:43:15 PM • Hitachi Heating... • Answered on Nov 02, 2022
2answers
Hitachi Ac white light blinking 7 times and outdoor fan not rotating and indoor not responding to remote
The thermistor on the outside unit has failed. Replace it.
10/21/2022 4:54:22 PM • Hitachi Heating... • Answered on Oct 21, 2022
4answers
My hitachi split ac is
this problem arises when u disturbe the remote settings. to make it operate again use the following procedure 1.on the power from stablizer 2.press the button in remote with 'key' sign once 3.now adjust the number displayed in remote 9 99 to 3 25 by using 'down '(temp adjustment button) key. 4.press again the button with 'key' sign 5.now ur ac is reinstate enjoy the breeeeeeeeezzzzzzzzzzzzzzzzeeeeeeeeeeeeee thanks atul sharma bikaner rajasthan india
10/12/2022 3:16:59 PM • Hitachi Heating... • Answered on Oct 12, 2022
Hitachi RAS-50yha3 green light flashes after 3 minutes orange timer light flashes sequences of 4 . Called technician , promptly told to buy new unit. Refuse to believe it cant be fixed.
It is a Split AC System, of course it can be repaired. Sounds like he doesn't know Hitachi units and didn't want to learn either. Contact Hitachi in Australia direct and ask for an authorised service company. https://www.hitachiaircon.com/au/news/hitachi-air-conditioner-error-codes-video-tutorials-for-professionals ./.
7/24/2022 10:42:30 PM • Hitachi Heating... • Answered on Jul 24, 2022
Hitachi air conditioner RUR-3U1. Orange timer light blinks after few hours of operation.
Hello, open flap, press and hold down button A whilst depressing the small reset button B using a pointed instrument.
6/22/2021 2:25:35 PM • Hitachi Heating... • Answered on Jun 22, 2021
2answers
Split A/C. Why is filter light blinking 5 times?
Could be time to clean or replace it
12/10/2020 6:36:02 PM • Hitachi Heating... • Answered on Dec 10, 2020
2answers
My hitachi split ac blinks green light for 12 times and stop working?
That means that the indoor unit is not communicating with the outdoor unit. Check all the cables between the two units, look for broken wires, corrosion and loose fittings
10/11/2020 3:02:15 PM • Hitachi Heating... • Answered on Oct 11, 2020
4answers
Hitachi ACE follow me red filter light is always on
the red light turns on automatically after 120 hrs of running to remind us for cleaning the filters. once you cleaned the filters and inserted back , then just keep ac in stand by mode, open the remote panel and press the button on extreme right bottom of the remote ( see carefully in the remote, there is very light image of the filter is made along with the button). red light will go off. no need to press the reset button.... enjoy
6/27/2020 2:46:51 PM • Hitachi Heating... • Answered on Jun 27, 2020
My hitachi split ac green light blink 4 times.what can i do
Good concept.Thanks for sharing
6/12/2020 6:42:32 AM • Hitachi Heating... • Answered on Jun 12, 2020
Hitachi Kaze Split AC, power light (orange ) is continuously on and the AC is not cooling or Turning on, please help?
The timer lamp (orange) flashes. The timer lamp flashes to indicate that the Streamer unit needs cleaning. After cleaning the Streamer unit, reset the lamp. (1) After cleaning, connect the power cord to AC outlet or turn on the circuit breaker. https://www.daikin.com/products/ac/services/troubleshooting/
4/17/2020 3:23:25 AM • Hitachi Heating... • Answered on Apr 17, 2020
4answers
LED LIGHT BLINKING OF HITACHI SPLIT AIR CONDITIONER
Did you figure out why the ac wasn't responding to the remote? I am having the same problem. I just cleaned out the filters but it's still not responding to the remote. I have already tried reset button in the remote, which didn't help. I am pretty sure that the remote is not out of battery.
12/9/2019 5:41:21 AM • Hitachi Heating... • Answered on Dec 09, 2019
I have hitachi inverter split ac.The timer light blinks continually &the ac does not work.what to do?
My Hitachi air-condition timer tight blinking 4 times . What can I do?
9/17/2019 12:34:03 PM • Hitachi Heating... • Answered on Sep 17, 2019
Hitachi 9000 BTU Split A/C Logo
2 questions posted
Top Hitachi Heating & Cooling Experts
jws1013
john h
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Heating & Cooling
Most Popular Question
hitachi inverter ac indoor light 3 time
  • Heating & Cooling
