20 Most Recent
Hitachi 24cc Straight Shaft Weed Trimmer | CG24EKSL Questions & Answers
Hitachi split air #RAS-25CHA
Normally these systems need to be shut down for at least 2 hours and overnight is better. After you restore power at the breaker wait at least 10 minutes for the self test procedure to finish.
Then make sure you are set to A/C chilled air as it defaults at every disconnect.
Happy Thanksgiving.
Hitachi 11 ton ductable 07 error code
there might be an error in your refrigerant levels or temperature that needs to be corrected. If you add more refrigerant gas, then this should remove the error.
Thank you.
My hitachi split ac is
this problem arises when u disturbe the remote settings. to make it operate again use the following procedure
1.on the power from stablizer
2.press the button in remote with 'key' sign once
3.now adjust the number displayed in remote 9 99 to 3 25 by using 'down '(temp adjustment button) key.
4.press again the button with 'key' sign
5.now ur ac is reinstate
enjoy the breeeeeeeeezzzzzzzzzzzzzzzzeeeeeeeeeeeeee
thanks
atul sharma bikaner rajasthan india
Hitachi ACE follow me red filter light is always on
the red light turns on automatically after 120 hrs of running to remind us for cleaning the filters. once you cleaned the filters and inserted back , then just keep ac in stand by mode, open the remote panel and press the button on extreme right bottom of the remote ( see carefully in the remote, there is very light image of the filter is made along with the button). red light will go off. no need to press the reset button.... enjoy
LED LIGHT BLINKING OF HITACHI SPLIT AIR CONDITIONER
Did you figure out why the ac wasn't responding to the remote? I am having the same problem. I just cleaned out the filters but it's still not responding to the remote. I have already tried reset button in the remote, which didn't help. I am pretty sure that the remote is not out of battery.
Hitachi window air conditioner E9 error code information
I believe that error code means the fan DC motor is faulty. Check the connections first, if all seems ok, I'm afraid you will have to contact your nearest Customer Service and arrange to have a service call. If the AC unit is still under warranty then you may not have to pay for any parts.
