20 Most Recent Neato XV-21 Pet & Allergy Automatic Vacuum Cleaner Questions & Answers
Neato robot turns on, fires up vacuum/brushes, but won't move - no error messages. What gives?
I have a Neahis to Botvac 85, had also problem, it started up then stopped. It is 2 or 3 years old, don't remember. but it started to ack very strange with the battery. then this start/stop problem came. I ordered a new originial battery and thought it should solve the problem but no it didn't After some time I decided to try again. Started Neato and it stopped after some time, then I wanted to see if the lidar was rotating so I removed the blue cover over the lidar and could see that it was rotating, then I touched it little bit and the neato started and started to clean my floor. so try this.
3/16/2018 6:49:33 PM • Neato XV-21 Pet... • Answered on Mar 16, 2018
tip
How to fix the neato vacuum
It's a great design BUT the weak point in the design is the quality of the 100uF electrolytic capacitors that they use on the main board. After 2-3 years these cause problems with the Neato not turning on (dim green lights only) and its vision gets worse so it has problems with eratic cleaning patterns and can't redock itself. in this video we show show to fix all those issues by changing the main board capacitors. It's like new again now! See it redocking itself late on in the video, it is about 50ft away in another room and comes back for charging! Here is a video showing a quick temporary fix and the full fix showing the change of all the electrolytic capacitors.
GET AN XV-21 FROM GOING HAYWIRE IN CORNERS
I suggest you remove power from the unit completely, including disconnecing the batteries. Reconnect and voila!
2/23/2015 8:58:51 PM • Neato XV-21 Pet... • Answered on Feb 23, 2015
My neato is showing a message :my vision was blocked. please press ok (3000). How do I fix this?
Dust off your drop sensors. Using a cotton swab, clean the two drop sensor windows on the bottom of your Neato Vacuum. Power cycle the unit, removing the batteries if necessary. You should be good to go.
9/26/2014 7:16:06 PM • Neato XV-21 Pet... • Answered on Sep 26, 2014
My neato d 80 tells me to open bin put switch to if i triy it will say battrey low need to charge battrey beattrey is new
It sounds like you are having some issues with your Neato D80 robot vacuum. Here are a few things you can try to troubleshoot the problem:
  1. Make sure that the bin is properly closed and seated in the vacuum. If the bin is not closed or seated correctly, the vacuum may not function properly.
  2. Check the battery to make sure it is fully charged and properly installed in the vacuum. If the battery is low or not properly installed, the vacuum may not function properly.
  3. Check the charging cord and charging port to make sure they are not damaged and are making a proper connection.
  4. If the problem persists after trying these troubleshooting steps, you may need to take the vacuum to a repair center for further diagnosis and repair.
1/4/2023 1:01:25 PM • Neato Vacuums • Answered on Jan 04, 2023
My Neato D3 Connect BotVac will not connect to the Internet.
check the below link I found on google https://www.google.com/search?q=Neato+D3+Connect+BotVac+will+not+connect+to+the+Internet.&oq=Neato+D3+Connect+BotVac+will+not+connect+to+the+Internet.&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
4/17/2021 1:54:15 PM • Neato Vacuums • Answered on Apr 17, 2021
Neato d5 will startup move from base then stop and run for thirty second then quit.
Press and hold the Start Button for 10 seconds. The robot will turn off. Press the Start Button again to turn the robot back on. Wait for the beeping sound to confirm the robot finished the reboot sequence.
2/27/2019 6:57:05 PM • Neato Vacuums • Answered on Feb 27, 2019
How do I assemble a neato robotic vacuum cleaner
Neato web site with contact information to request assistance. https://support.neatorobotics.com/hc/en-us Neato Robotics
10/8/2018 12:28:35 AM • Neato Vacuums • Answered on Oct 08, 2018
Neato XV-21 Pet & Allergy Automatic Vacuum Cleaner Logo
Popular Tags
6 questions posted
Top Neato Vacuums Experts
john h
Are you a Neato Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Neato Vacuums
  • Neato Vacuums
Most Popular Question
neato robot turns fires up vacuum
  • Vacuums
