20 Most Recent Karcher WV50 Window Vacuum Questions & Answers
look here
https://www.aliexpress.com/item/3V-0-2A-12000RPM-65Gcm-Mini-Micro-DC-Motor-for-DIY-Toys-Hobbies-Smart-Car-MOTOR/32950349790.html?spm=2114.search0104.8.4.74a81e90XHPlJW
Karcher WV50... | Answered on Feb 27, 2019
Take it apart and see what is stopping it (the motor) from turning .
Karcher WV50... | Answered on Aug 19, 2018
I had the same issue and after much exploring I discovered just a tiny bit of corrosion in the switch. To repair, remove the squegee section, and water bottle, so you just have the base unit. Then remove the bottom plastic cover and unfasten all the screws. Now remove the switch. With a fine Exacto knife and a magnifyer remove the switch and open it. Check it for corrosion this is whats causing it to stay on. Carefully scrape out the corrosion with the Exacto tool and then carefully reassemble. The light should switch off. You can also test it before reassembly just to make sure all the corrosion is gone.
Karcher WV50... | Answered on Mar 01, 2016
Might need new batteries.Hope this helps
Because the switch is broken and stuck in the "on" position. Until you fix it all you can do is plug it in and out for operation. If you are handy you can take the switch out, make the repair of the broken part, and reuse.
They wanted 35 dollars for the switch on my Karcher power washer. Yeah, right!
Karcher WV50... | Answered on Nov 24, 2015
Hi there, if it's anything like my WV50 - which we use for the shower - you'll find that it clogs up after some time and needs to be cleaned out. I've created a video that shows you how to open the head of the unit and clean out any obstructions.
In our case as we use it for the shower, it tends to get clogged with hair, shampoo and conditioner. You may well find that as you use yours for floors that there is also a similar problem.
All the best and I hope the video helps.
Karcher WV50... | Answered on Oct 26, 2015
You need a new battery. I could describe how to rebuild the old one if you are so inclined to do that type of thing. It would save you some money over buying a new one. It looks like it is a specialized piece of cleaning equipment and buying a replacement battery would be fairly expensive.
Karcher WV50... | Answered on Jul 18, 2015
There are no parts specially available but you can find the bearings aftermarket by matching the number on them.
Karcher WV50... | Answered on Mar 27, 2015
It could be your charger mine does not work but it flashes all the time sorry I can't help you A.Rudd.
Karcher WV50... | Answered on Mar 10, 2015
No it is not it is a tight fit on clips on battery,.thanks be very carful wires very hard to get off thanks A Rudd
Karcher WV50... | Answered on Mar 07, 2015
Karcher WV50 Window Vacuum Logo
76 questions posted
Top Karcher Vacuums Experts
Mark Bowens
Mark Bowens
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Karcher Vacuums
  • Karcher Vacuums
Most Popular Question
unit wont swich off
  • Vacuums
