20 Most Recent
Rubbermaid Reveal Spray Mop Kit, FG1M1600GRYRD Questions & Answers
Rubbermaid Reveal mop trigger sticking
I bought 2 rubbermaid reveal spray mops before I figured this out. You'll need a Phillips and flat head screwdriver & a can of WD40. On the compartment that holds the liquid cleaner bottle there are 2 screws and 1 screw on the connector piece to the mop head. Unscrew all three. The one by the mop head came out and the other two stayed in their holes. Then with a flathead screwdriver gently pull the seam along the side apart. You only need 1/2-1 inch of a gap. If you pull it open all the way you'll pop a few other pieces out of place and have to piece them all back together- so gently! Then spray some WD40 in along the exposed spring using the red straw that comes with the can. Close the gap, hold it together and try the trigger a few times. If the trigger is still sticking spray more WD40 in until it frees up. Then screw your screws back in and it's as good as new!
How can i make this friggin spray work
When your Reveal will not squeeze you have o-ring swell on the piston which squirts the fluid out. I think the piston rubber swells under the influence of the solvents that people use to clean their floor. My fix, take it apart, and drill out (ream) the plastic cylinder the piston moves up and down in so it moves freely.Now it works fine. I also stretched the spring a little.The designers forgot about o-ring swell. Remember the Challenger?
Rubbermaid reveal mop won't spray
I know this question is a little old... but I had the same problem and I figured it out! Unscrew the red top to the bottle. Under the top there is a gasket (leave that alone) and a little clear plastic plug blocking an air hole. Pull the little plug out and put it back in the holder. (Be careful, liquid will come out of the hole). This allows for air and cleaner to flow through.. so viola! It's spraying! I was so mad when it didn't work (brand new). I wish it had come with this little tip on the packaging! Have fun! :)
How do i fix a vacuum line hose on a car that's been cut?
Alot depends on the type of hose. There are plastic hoses and rubber hoses. Generally you can use a smaller plastic connector to connect two rubber hoses together and visa versa, Make sure it is a snug fix. You could also use an adhesive to keep it together.
3/31/2024 3:39:13 PM •
Vacuums
Answered
on Mar 31, 2024
How to empty a etl vc-h3301 vacuum cleaner
How to open it to see if the fuse is blown. I removed the three screws I saw. I feel that there is another which prevents me from opening it in two. I looked under the tights, I removed the plate where the two buttons are located. I can't open it.
3/21/2024 4:57:04 PM •
Vacuums
Answered
on Mar 21, 2024
