20 Most Recent Singer 8763 Curvy Computerized Sewing Machine Questions & Answers
could be a computer problem, if the problem keep happening the machine needs to be checked
Singer 8763... | Answered on Feb 17, 2016
The key word is generic. Obviously, the foot obtained from Creative will not fit. However, there may be other generic parts available that are more likely to fit.
Singer 8763... | Answered on Feb 15, 2016
there are several things that may cause this situation.
the needle may not be seated all the way up where it is supposed to be.
here is a site that may give you more insight.
How can fix the needle hitting the bobbin case on my sewing machine
Singer 8763... | Answered on Mar 05, 2015
sounds like a blunt needle,or tension at wrong setting.replace needle first.adrian,,,,
Singer 8763... | Answered on Feb 12, 2015
470952 looks more like a serial number than a model number for a Singer branded sewing machine. However, the known Singer serial numbers that do not have a letter prefix start at 611,000. See http://ismacs.net/singer_sewing_machine_company/serial-numbers/singer-sewing-machine-serial-number-database.html , if you have additional characters in the number. These early sewing machines do not have a model number. You can find some Singer manuals here: http://ismacs.net/singer_sewing_machine_company/manuals/singer-sewing-machine-manuals.html . Most are available here: https://www.singer.com/support .
If there is a three-digit prefix to the model number on the sewing machine label, then you have a Kenmore branded sewing machine. Some of these manuals might be online. However, without the prefix, I can't find the correct manual. You can try here: https://www.searspartsdirect.com/ . Manuals for Kenmore sewing machines made before 1990 are probably not online.
I hope this helps.
Singer Sewing... | Answered on Nov 05, 2019
  • Sam Guffey Nov 04, 2019If you have the manual, there are, usually, diagrams that indicate where. Just be sure to follow manual's suggestions; too much oil can be bad for your machine. While many parts need oil, usually one drop is all it takes. There are many parts in a machine where oil can cause the machine to malfunction.
    If you don't have a manual, you can get a free pdf at Singer.com/support
Singer Sewing... | Answered on Nov 04, 2019
It`ll have to be serviced often new belts are needed
Singer Sewing... | Answered on Nov 02, 2019
You will need to track the wire connections back to the two hot wires. Hook them up to the hot wires in any order and it should work, since it is controlled by the light switch. Hope this helps. Sincerely, Amender (2019-NOV-01).
Singer 8763 Curvy Computerized Sewing Machine Logo
9 questions posted
Top Singer Sewing Machines Experts
Kelley Buchanan
Kelley Buchanan
tsalagi152
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Singer Sewing Machines
Most Popular Question
am ttying wind bobbin when stsrt machine
  • Sewing Machines
