They are all called 'Navigator' :>D
https://www.google.com/search?q=Shark+Navigator
When switch to carpet, the difference is that the brush roller turns. When it is on hard floors setting it doesn't. Remove the base plate, remove the brush and the belt. There is likely something wrapped around the drive spindle or clutch.
How to reduce high pitch noise of Shark vacuums
Digital Trends
https://www.digitaltrends.com > Smart Home > Guides
Apr 6, 2022 - You can adjust the height on a Shark vac to accommodate certain levels of rugs, carpet, etc. If the vac has been set too high for the current ...
Loud rotating carpet brush noise: Just got my new Shark
https://www.fixya.com > support > t15932203-loud_r...
It seems that your drive belt for the beater brush is stretched. This is a common problem -- if you flip the vacuum over so you are looking at the bottom, you ...
4 Reasons Why Shark Vacuum Is Making Noise
howtofixit.net
https://howtofixit.net > shark-vacuum-making-noise
Aug 20, 2021 - Another cause behind the loud noises coming from your Shark vacuum is an overly dirty or damaged filter. Remember: air must be able to pass ...
Loud Or High Pitch Noise ·
Blockages ·
Rattling Noise ·
Belt Snapped In Powerhead
Does anyone know why my vacuum might be making a ...
Reddit · r/VacuumCleaners
10+ comments · 2 years ago
I agree, suction relief valve is popping because of a blockage. Check the extension wand too. The air goes from floor head, lower hose, ...
6 answers · Top answer: That's the suction relief valve. There is a blockage somewhere in the system, either in the ...
Loud Air Coming Through Side Vent, Brushroll Not Spinning
Dec 4, 2020
How to fix this without taking it in? Shark vacuum - Reddit
Sep 27, 2022
Shark making weird suction noise : r/VacuumCleaners - Reddit
Aug 13, 2022
Shark Vacuum Making Strange Noise and Not picking up Dirt
Sep 22, 2022
More results from www.reddit.com
