20 Most Recent Holmes Products HAP422-UC Air Purifier Questions & Answers
3answers
Red light on air filter
After spending hours searching for this supposed little hole easy to miss, I called customer service. I found out that it's easy to miss because it doesn't exist!
Here's the correct answer: Once you've replaced the filters, turn the unit back on. Then, with the machine running, press and hold down the on/off power button for about two seconds. The red light will flash and then turn off.
12/18/2022 3:32:22 PM • Holmes Products... • Answered on Dec 18, 2022
I have a hunter air purifier model number 36316 and need to know how to change the filter
Hello, this is Ava with Think Crucial. To change the wick filters of your humidifier: 1. Turn off the unit and unplug it from the wall outlet 2. Remove the tank for the housing. 3. Locate the 3 lock tabs in the base of the unit. Turn them clockwise until the base of the tab lines up with the indentions in the base and lift off the housing. 4. Locate and turn the lock tab clockwise on the base holding the wick fram. Remove the wick frame and set it aside. 5. Remove the old wick by pulling the bottom of the wick out of the frame first and discard. 6. Insert the new wick top first. Ensure wick is in between the tabs at the top of the wick frame then slide the bottom part of the wick into the fram, making sure not to crush the bottom corners of the wick. 7. Reassemble the unit and refill the water tank if necessary. 8. Turn the unit back on and resume operation. You can purchase a wide variety of high quality Hunter replacement parts for your Hunter Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 http://www.thinkcrucial.com/search?page=1&q=hunter&type=product I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
10/27/2016 11:05:17 PM • Holmes Products... • Answered on Oct 27, 2016
When bar light is on level 3 what does that mean holmes air purifier
Hello, this is Ava with Think Crucial. There are 3 settings for optimum air filtration. You can operate your Holmes air purifier continuously on the Medium (2) setting. It's rugged motor has been designed to give many years of use. For quieter operation (such as bedroom), select the Low (1) setting. When high levels of air polution are present, select the HIGH (3) setting to quickly circulate and filter the room air. You can purchase a wide variety of high quality Holmes replacement parts for your Holmes Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 http://www.thinkcrucial.com/search?type=product&q=holmes I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
10/27/2016 10:34:19 PM • Holmes Products... • Answered on Oct 27, 2016
Hepa filter
The red light indicates a plugged filter. Replace the filters plug the machine in and get a paper clip. Streighten out the clip and put it through the tiny hole in the top. You'll feel it push a switch that will give a click you can feel. Keep holding the clip wire down for several seconds. When the red flashes remove the clip wire. The light will stay off if the filter is clean.
8/3/2013 12:39:48 AM • Holmes Products... • Answered on Aug 03, 2013
Red check light came on today,i replaced filters
yes hold down the power button for about 10 seconds with power button on
1/7/2011 10:27:17 PM • Holmes Products... • Answered on Jan 07, 2011
Air purifier
if you want. you can print it off of your computer. you can go to www.jardenstore.com
then click on holmes and in the search bar to your top left corner type in your model number hap424. scroll about two clicks and you will see your unit. click on that picture. then on that screen there will be the manual. it will download in adobe reader. if you have any other questions please don't hesitate to ask.
8/23/2009 8:27:45 PM • Holmes Products... • Answered on Aug 23, 2009
Owners Manual Holmes 424G need one
i do apologize that you don't have a manual for your unit. the best way to get it is type in the address bar www.jardenstore.com
then when the page comes up you should have a list a lot of company's, click on holmes. then when that page comes up in the search bar to the top left. type in 424g. the picture will come up. click on that pic, and the right below that pic once the other page comes up it will have the model number and then right underneath that is the manual click on that and it will download in adobe reader
8/23/2009 8:07:25 PM • Holmes Products... • Answered on Aug 23, 2009
I completely took apart my holmes air purifier to do a deep cleaning to get the fans and evreything dust free. need diagram to put back together. HAP9422 (model)
Hello, this is Ava with Think Crucial. This is the manual of your Holmes model number: Holmes HAP9422 Product Manual Hope this was helpful. You can purchase a wide variety of high quality Holmes replacement parts for your Holmes Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 http://www.thinkcrucial.com/search?type=product&q=holmes Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
9/27/2017 6:32:13 AM • Holmes Products... • Answered on Sep 27, 2017
Red light keeps blinking
Hello, this is Ava with Think Crucial. It looks like you may need to change your filters. It is advisable to change filters every 3-6 months for optimal use. When replacing your filters, make sure that the unit is turned off and unplugged from the power. Once filters are replaced, turn on your unit then press and hold the filter check indicator button for 3 seconds. The indicator light will blink 3 times and turn off, and reset the filter change timer. You can purchase a wide variety of high quality Holmes replacement parts for your Holmes Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 http://www.thinkcrucial.com/search?type=product&q=holmes I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
10/27/2016 10:27:49 PM • Holmes Products... • Answered on Oct 27, 2016
Red filter light does not change to green when filter is changed
Call the manufacture and tell them it is defective and to please replace it.
4/2/2014 8:07:01 AM • Holmes Products... • Answered on Apr 02, 2014
0answers
Holmes Products HAP422-UC Air Purifier Logo
20 questions posted
Top Holmes Products Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Holmes Products Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
  • Holmes Products Air Purifiers
Most Popular Question
red light air filter
  • Air Purifiers
