20 Most Recent Daewoo DWD-WD1353RC 4.5 Cu. Ft Capacity Washer 1 300 RPM 11 Cycles Questions & Answers
3answers
My Daewoo does not want to spin, any suggestions?
first does all of the water pump out when wash cycle is done? if not then check your drain lines and see if pump is coming on. if it is not then it wont let the washer spin,
4/25/2024 12:06:19 AM • Daewoo Washing... • Answered 8 hours ago
2answers
Error code OE in my washing machine but not easy!!
As these manufacturers use the same type board in their machines, video will help you
2/27/2024 10:05:11 AM • Daewoo Washing... • Answered on Feb 27, 2024
Please i need Daewoo washing machine DWC-LD1213 manual
I could not find DWC-LD1213 manual. I am sharing the link for same series manuals. It may help you. User manual Daewoo DWC-LD1412 (English - 32 pages) Daewoo DWC-ED1212 user manuals download (nodevice.com) Daewoo DWD-1213'S Manuals ' ManualsLib
1/24/2024 12:36:18 PM • Daewoo Washing... • Answered on Jan 24, 2024
2answers
My DAEWOO washing machine shows E9 error . How can I fix it.
Check pressure switch or level sensor
12/31/2023 10:44:21 AM • Daewoo Washing... • Answered on Dec 31, 2023
Spin not speed Deawoo Washer.
Usually slipping belt or broken drive belt. ..
12/26/2023 9:18:39 PM • Daewoo Washing... • Answered on Dec 26, 2023
I have a Mini Daewoo washing machine. Recently the operating buttons have begun to not work when you press them. If I press a few more times, they eventually work. Is this a part I can replace?
You can try spraying the buttons with electrical switch cleaner. If there is a membrane behind the buttons, you will need to remove it and clean the contact that are behind. Or you replace the panel, but it likely is part of the main control board. Need model number in this Search Query! https://www.google.com/search?q=Mini+Daewoo+washing+machine+parts ..
9/7/2023 8:57:32 PM • Daewoo Washing... • Answered on Sep 07, 2023
Daewoo Mini Washing Machine Error B8
It could be the starter capacitor for the electric drive motor. You may also look to see if the brushes that sit on the armature are not stuck and free to travel while sitting completely flat on the armature to make the correct contact. There is also a speed sensor for the motor that may be bad. CAUTION: Make sure the machine is unplugged and the capacitor is drained to avoid shock.
1/7/2023 5:48:38 AM • Daewoo Washing... • Answered on Jan 07, 2023
Daewoo Washing machine flashing lights
The only way to answer this is to contact repairers in you local area.
11/22/2022 4:54:59 PM • Daewoo Washing... • Answered on Nov 22, 2022
What the belt size for Daewoo washing machine F1013
You don't order by size, you order by 'make model part'. https://www.google.com/search?q=Daewoo+washing+machine+F1013+spares ..
10/15/2022 2:45:58 AM • Daewoo Washing... • Answered on Oct 15, 2022
Washing machine Daewoo Nanosilver DWF 800 MPS PARTS
Hi, Please check ebay to help you find the spare parts. Thank you.
9/27/2022 7:33:00 PM • Daewoo Washing... • Answered on Sep 27, 2022
My Daewoo air bubble washer. My machine stopped agitating, everything else works. It is like it is out of gear on the agitate cycle?
If it is a top loader, there is a clutch, with clutch dogs and below that, a gearbox. It is not a nice job full of black grease and often needs special tools. Call for service.
4/30/2022 1:40:56 AM • Daewoo Washing... • Answered on Apr 30, 2022
I have a Daewoo DWF-65, it's not moving the clothes around at all but it does spin
possible cogs under agitator bad or loose belt
3/9/2022 8:37:51 PM • Daewoo Washing... • Answered on Mar 09, 2022
3answers
My Daewoo Washing machine shows error code OE & it won't work actually what's the problem? tq
Watch this video Its content all error code and solution
2/2/2022 7:49:07 PM • Daewoo Washing... • Answered on Feb 02, 2022
2answers
Where I could find the Daewoo Front Load Washer 7kg DWD-N1011 DWD-N1011 Circuit
TRY A DEAWOO DEALER
11/25/2021 3:14:54 AM • Daewoo Washing... • Answered on Nov 25, 2021
Daewoo washing machine DWC ED 1212 dosnot start
10/11/2021 10:14:45 PM • Daewoo Washing... • Answered on Oct 11, 2021
My Washing Machine Daewoo DWF 200P Displayed ( E9 ) in screen
Daewoo Washing Machine Error Fault Code = E9 Fault Detected: Pressure Sensor Error Washer Has Detected: Error with the pressure switch or level sensor Check / Repair / Fix = Wiring to level sensor - Level sensor
Daewoo Washing Machine Error Fault Codes
https://removeandreplace.com > 2015/11/02 > daewoo-...
Nov. 2, 2015 - The Daewoo generalized error fault codes below are to give you an "idea" as to what part is at fault. ... Daewoo Washing Machine Error Fault Code = E9 ... If your Daewoo Washing Machine Error Code is not listed here, check ... Mine is Daewoo washing machine DWF-8288, showing E1 and won't spin and ... ..
6/7/2021 7:01:54 PM • Daewoo Washing... • Answered on Jun 07, 2021
Daewoo DWD-WD1353RC 4.5 Cu. Ft Capacity Washer 1 300 RPM 11 Cycles Logo
4 questions posted
Top Daewoo Washing Machines Experts
Paul Bade
vince
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Daewoo Washing Machines
Most Popular Question
daewoo dwf 300slds washing machine
  • Washing Machines
